99 maxima- won't engage in any gears
Old Jun 8, 2010 | 05:57 PM
finny's Avatar
I have an 99 maxima with an auto tranny with 199,978 miles on it. Car has been running absolutely perfect. Today i'm going to make a left into traffic and I get a clunk and the car stops moving and wont engage in any forward or reverse gear.
Car goes into park and sounds like its doing something but I get nothing more than a buzzing sound and acts as if the cars in nuetral. I've had the occasional slipping on a cold morning in that past but otherwise no problems what so ever. Car is on an incline now but fluid level seemed within range, no leakage or abnormal smells or colors. I checked the codes and theres a P1320 (ignition related) thats been on for months and nothing else.
I tried searching and the only thing I came up with was checking cv's (which I did and they seem fine). Only other guesses are torque converter/solenoid/transmission itself.
Anyone have any other suggestions or things to check? I really can't leave the max be done this close to 200k
Old Jun 8, 2010 | 06:06 PM
maxed_out_99's Avatar
Sounds to me like you blew apart your diff
Old Jun 8, 2010 | 06:30 PM
3.5pearlmax's Avatar
Could be a number of things... Just save the time and buy a new one and install..i know it sucks blew apart my 5-speed last year
Old Jun 8, 2010 | 06:47 PM
finny's Avatar
I've been reading up since i posted and it does kind of seem like rather than troubleshooting and diagnosing the problem it would prob be cheaper to throw in a tranny and be done with it.
Old Jun 8, 2010 | 06:51 PM
that what i did
Old Jun 8, 2010 | 07:38 PM
luke95gxe's Avatar
did you check to see if one of your drive axles poped out or broke
Old Jun 9, 2010 | 03:15 AM
finny's Avatar
I couldn't really get under the car the way it was sitting, but jacking up each wheel it appeared that everything was normal and a shake and pull on each cv felt ok.
Old Jun 9, 2010 | 07:49 AM
njmaxseltd's Avatar
Most likely an axle failure. Park is a hard pin within the tranny and if your not getting that to work I'd definately look really hard at your axles. Either a CV has completely failed or seperated within the boot.
Old Jun 9, 2010 | 08:07 AM
98Maximo's Avatar
Kinda sounds like what happened to this guy
Old Jun 9, 2010 | 09:55 AM
finny's Avatar
It does engage it park, when shifted into reverse and any forward gears it acts as if the car is in neutral, regardless of throttle. I think I may move the car to somewhere where I can get under it and take a closer look at the CV's. They both were replaced prob about 60-70k ago with remans from advance or autozone so I wouldn't doubt their failure. That sure would be an easier fix.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
