0703 after cleaning egr
Old Jul 7, 2010 | 04:52 PM
eFLO's Avatar
so after cleaning my egr tube it cleared my 0302 code for egr, but after about 50 miles i got code 0703. from what i gathered it could indicate an air intake leak, i did replace the tb gasket but not the iacv gasket could this be where my problem is?
Old Jul 7, 2010 | 06:40 PM
jholley's Avatar
Getting code 0703 shortly after remounting various air intake components then an air leak is probably the culprit. I installed a new IACV yesterday but I didn't bother replacing the gasket. While cleaning the IACV last fall the old gasket was still solid so I just applied gasket sealant to the gasket yesterday.
With the engine idling spray a can of throttle body or air intake cleaner around those components you remounted. If you have an air leak then the cleaner will get drawn in. Don't bother using the straw.
Old Jul 7, 2010 | 06:46 PM
Trini Boom's Avatar
Highly doubt it. I would back track to all the hoses that you disconnected to remove the job. Check to make sure that all of them is connected and the hoses do not have any tears in them.
Old Jul 7, 2010 | 06:48 PM
95Maxed's Avatar
I cleaned my throttle body and egr last weekend. Got a leak. Ended up being the seal in the TB.
Old Jul 8, 2010 | 05:16 AM
Trini Boom's Avatar
Oh yeah? I also did my valve covers with all the gaskets at the top replaced with OEM gaskets and I don't get leaks....unless maybe you did not tighten it enough.
Old Jul 8, 2010 | 05:45 AM
95Maxed's Avatar
No I needed a new gasket. The carbon that had built up had been sealing the leak, and when it got cleaned out... Well, yea haha
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
