Animal attack and 2 speed trans
Old Jul 11, 2010 | 12:48 PM
jjamzman's Avatar
My Max was running fine one day and inoperable and barfing fluid the next. My wiring harness to the crank position sensor, the crank reference sensor and one trans cooling line were literally chewed off over night by some kind of animal!
After finding and fixing the damage, I now have a trans code 0734 "4th gear wrong ratio". I only have 1st and 3rd gears. I can't find any other wiring damage. HELP!!!
John
Old Jul 11, 2010 | 01:08 PM
FallenOne's Avatar
shes in limp mode, i think. make sure shes topped off with fluid, than reset the ecm. see if it comes back.. otherwise you might have to bring it to a dealer and have the tcm looked at.
Old Jul 11, 2010 | 02:38 PM
jjamzman's Avatar
FallenOne,
That makes some good sense. I will try that. Thanks a lot.
John
Old Jul 11, 2010 | 04:54 PM
Trini Boom's Avatar
Those splash guards are important as you can see. You should get them replaced to aviod this problem again in the future. Now you said you have a code for "4th gear wrong ratio" right? But also you stated you only have 1st and 3rd gears...so what happened to 2nd gear?
Old Jul 11, 2010 | 05:12 PM
jjamzman's Avatar
Trini Boom,
The spash guards were all on and intact.
4th is electronically engaged, but I don't know about 2nd gear....I hope the limp mode theory is correct.
John
Old Jul 11, 2010 | 11:19 PM
FallenOne's Avatar
dont hold me to it, but ive had that happen once before. Is your O/D light on or flashing? also congrats youve managed to get the best unbuyable mod haha. 1st+3rd=Beast
Old Jul 12, 2010 | 11:12 AM
1992maximase30's Avatar
limp home mode is 3rd gear.
the tcm keep's the car in 3rd gear when it's in lhm.
does it feel like 4th gear is kinda iffy?
can you shift into second gear manually?
Old Jul 12, 2010 | 06:45 PM
jjamzman's Avatar
Someone had to do it.....but why me!!
Old Jul 12, 2010 | 06:56 PM
jjamzman's Avatar
does it feel like 4th gear is kinda iffy? - There is no 4th gear attempt at all and the converter also does not lock up, so everytime you let off the gas, the tach goes to idle. It fooled me at first because I thought it shifted and dropped rpm, then I realized I just backed off on the throttle and it was free wheeling.
No. It starts in 1st then just slips where 2nd should be...doesn't engage, then collects itself slowly and finds 3rd. 1st and 3rd are smooth and quiet. I had it up to 75 in 3rd and it was fine. If I try to force a downshift to 2nd, it attempts the shift, but just doesn't engage...when I let off it goes back to 3rd.
John
Old Jul 12, 2010 | 06:59 PM
jjamzman's Avatar
Originally Posted by FallenOne
dont hold me to it, but ive had that happen once before. Is your O/D light on or flashing? -The O/D light is working normal, it is off until I manually disengage the O/D by the button.
- Is there a prize???
Old Jul 12, 2010 | 09:05 PM
FallenOne's Avatar
unfortunately no... You seem to have some wonderful tranny issues my friend. Did you ever check the color of the fluid or anything? If sufficient material was in the fluid it could be essentially tac-welding the clutch packs together...
Old Jul 14, 2010 | 12:21 PM
jjamzman's Avatar
Wonderful??? I change the fluid every year, and since I had to change the trans line anyway it got fresh fluid again last week along with Lucas trans treatment.
John
Old Jul 14, 2010 | 10:05 PM
FallenOne's Avatar
ooh.. Theres yer problem... sometimes it can still up trans material and some of it can get stuck in the shift solenoid chambers. This could be the reason.. You might want to look into checking out your previous work, as well as mabey a new tranny.. so sorry buddy.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
