How long does the stock struts last?
Old Dec 13, 2001 | 10:57 AM
MaxPerformanceSE's Avatar
I'm itchin' for an Eibach/AGX combo
Old Dec 13, 2001 | 01:08 PM
matty's Avatar
Re: How long does the stock struts last?
My guess is they will probably start to feel soft at like 120K-140K..but my guess is just as good as yours
Old Dec 13, 2001 | 01:16 PM
carnal_c30's Avatar
Former Sponsor
depends on how you drive where you drive...
i think mine are getting a bit soft at 50K miles maybe its jus me.. haha but maybe its cuz i have a GXE and the shocks are just softer
Old Dec 13, 2001 | 01:31 PM
SuDZ's Avatar
By us in Lowell and what not the roads are not all that bad and should stick it out for a while. I think you will just break down and get the new setup before they actually go out on you. But on my last car they lasted me like 100K until the rear ones went. But that was on a crappy Dodge intrepid.
SuDZ
Old Dec 13, 2001 | 01:40 PM
Eric L.'s Avatar
Depends really how bad your roads are. Harsh roads put increased load on the struts, causing premature wear. When I switched from stockers to Tokicos at 30k miles, one of my stock front struts was already leaking.
Nissan doesn't equip their vehicles with very good struts. As a rule, my guess is that by 60k (after approx 5 years), the stock struts will begin to feel tired.
Old Dec 13, 2001 | 03:59 PM
SmoothMax's Avatar
OG
Well, I've got about 102k on the odometer and I have intrax springs on stock shocks/struts and still goin strong. For how much longer? I dunno, they're startin to get soft but I estimate they'll last another 5-6k.
Old Dec 13, 2001 | 06:07 PM
nixima's Avatar
110K with H&R on the last 10K. Stock SE struts/shocks are still holding up pretty strong.
Old Dec 13, 2001 | 11:08 PM
krzymax's Avatar
Maxima owner since 2000
how would you know if your stock struts are dying on you?
Old Dec 13, 2001 | 11:20 PM
KWheelzSB's Avatar
Do the "bounce test."
Open both the hood & trunk.
Go to each corner of the car in succession and push down quickly/forcefully on solid surfaces inside the fender and inside the edge of the trunk (using much of your weight), then release immediately. (The idea is not to push down on paint or body panels, where you could cause damage)
If the car bounces two or more times before settling to a stop on that corner, then that strut/shock is showing signs of wear.
Also, inspect the exterior of the shock cartridges for fluid leaks. If you have a leak, replace your struts/shocks as a set. (unless they're relatively new & there's a defect in one of the units)
Old Dec 14, 2001 | 01:39 AM
Eric L.'s Avatar
Unfortunately this test will only tell you if you have a completely blown shock/strut. Modern cars such as the Maxima has firm enough struts in stock form such that even if they are worn out, they may not bounce up and down on the "bumper bounce test." Keep in mind the bumper bounce test is one of those old time proven tests, used on old old cars. Remember those 1970's and 1980's Buicks with the supersoft suspension? This test was used on those too!
As for leaks, I believe a little leakage is actually normal as a shock/strut wears...think I heard that one from DBM. But a massive leak, and you've got a blown strut.
As for testing for partially worn struts, I'm not sure. If the car doesn't feel right on the bumps and dips, that's a clue right there.
Old Dec 14, 2001 | 11:31 AM
98sterlingmist's Avatar
I have 62K on my 98 SE and my mine are getting very soft. I hit a speed bump, on a slow roll, and the car bounces 2 or 3 times. I can wait for an excuse to purchase springs and aftermarket struts.
C
Old Dec 14, 2001 | 11:51 AM
SuDZ's Avatar
C
I got about the same year and milage as you. I think my excuse it gonan be spring. I am gonan ride out my struts till then then upgrade everything.
SuDZ
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maximan190
Dec 16, 2015 06:01 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
