Evap Fumes in Cabin
Old Jul 19, 2010 | 10:22 AM
MoMurderah's Avatar
Evap Fumes in Cabin
So here's the problem, I've been smelling some fumes while driving but not when I stop and poke around the engine bay. They kinda smell like sweet gasoline. Now I've done some research on this topic and here's what I have:
No CEL but ghost Codes thrown:
P0505- IACV
P0325- Knock Sensor
I've already cleaned the EGR valve and replaced the Evap Canister. Smell seemed to disappear but it came back after 300 miles or so. Checked the lines and nothing seems to be leaking. The only other thing I think it could be is the Purge Valve but that's kind of expensive. Any inputs on what else to check is greatly appreciated.
Old Jul 21, 2010 | 02:18 PM
MoMurderah's Avatar
So no suggestions?
Old Jul 22, 2010 | 04:43 AM
ajm8127's Avatar
The filler neck on my car was rusted and it would cause the car to smell like gas. Initially, I wasn't seeing any EVAP codes but once the hole opened up, I did get a code. I seems like the size of a hole that is required for enough gas fumes to seep out to the point of being detectable by smell is very small. Much smaller that the diameter of a hole required to trip an EVAP code.
Because you are smelling gas in the cabin, I would take a look under your rear seats, and in the trunk. Some cars have an access for the fuel pump under the rear seat, I'm not sure if the maxima is like this.
I know another member had a problem with Best Buy in that they pierced his gas tank while installing some car audio equipment. This means that the tank is very close to the metal that makes up the rear seat area and the trunk floor.
I'm just brainstorming, sorry I don't have any concrete solutions for you.
Do you smell gas in the cabin with the windows up or down?
Old Jul 22, 2010 | 02:09 PM
MoMurderah's Avatar
Windows up and down.
Now I did some spelunking and found what smell it was. It's the purge valve hole on the evap canister. This hole is connected to a hose that leads to a filter thing then a shorter hose and then just ends. If this is how its supposed to be, how come I haven't ever smelt this before?
Old Jul 22, 2010 | 05:09 PM
soto2635's Avatar
did u over fill ur tank when u filled up?? i had the same issue when i over filled my gas tank
Old Jul 23, 2010 | 05:28 AM
ajm8127's Avatar
The purge control valve is a disc shaped plastic piece on top of the engine. The purge control volume valve is a metal part on top of the IM. The vent control valve is connected to the EVAP and leads to a device meant to keep debris out and then to an open tube. The EVAP system can be fairly confusing, so using the correct names for the parts of the system is a necessity. Looking in the EC section of the FSM helps.
I am confused as to what you mean when you say there is a hole in your canister. There should not be any holes. This is a closed system that has to hold pressure to pass a diagnostic check. Could you take a picture of this?
Old Jul 23, 2010 | 05:42 AM
cashoit's Avatar
Ajm is right. The entire EGR system should be closed system. If there are any leaks or disconnected hoses, the CEL will come on.
Old Jul 23, 2010 | 02:52 PM
FallenOne's Avatar
have yo bothered to check the physical lines under the vehicle and the engine bay?
Yesterday i somehow managed to lose over half a tank of gas in under 30 miles. WTF?
I looked under the car as i arrived at a friends house.
A Chewed on Fuel Line. Yes Chewed On by a F***ing Squirrel. I Cant Make This **** Up!
So, Vise Gripped the already Siphoned Line which made it constantly leak, even when off; cut the line and put it back on the Plastic/Brass Line.
AaronL
Aug 8, 2020 10:31 AM
tseng1023
Oct 15, 2015 08:30 AM
uttadms31
Sep 30, 2015 05:24 AM
homeofbacon
Sep 23, 2015 07:17 PM
dcam0326
Sep 7, 2015 07:26 AM
