CEL: Rear O2, Camshaft, Multiple misfires. Bad idling on startup
Old Aug 11, 2010 | 12:03 PM
Pint07's Avatar
Alright, I've had problems with my idle speed for a while when the engine is cold. 245k on the car. When I first start up, my car will sputter and stall several times before I'm able to get off. Once I accelerate though, this problem goes away.
I've been having trouble passing emissions. I had codes for both of the front O2 sensors. I cleaned them, reset, drove, and had it tested. The light came back on as she was testing it -.-, failed for all 3 O2 sensors. I changed both of the front O2 sensors, reset, and the light comes back on the 2nd start, gives code for the rear O2 sensor. I take the car to the shop the other day, they read the codes, reset, and tell me that my ECU is probably bad, because they got more codes than just O2 sensors now. I come home, do a reset myself last night. I start up this morning, CE lights off, everything's fine. I get about 6 starts, still having the startup idle/stalling problems, and the 7th when I put the car in reverse the CEL comes back on. I drive home, read the codes and I have 0101- Camshaft position sensor, 0701 - multiple cylinder misfire (i'm guessing from the stalling), and 0707 for the rear sensor. I personally think my ECU is fine. I've cleaned my TB, EGR tubes, IACV, and MAF recently, and changed my fuel filter to fix a stalling problem I was having.
Do you think my ECU is actually bad, or do you think replacing the rear O2 sensor and Cam position sensor will fix the codes and allow me to pass emissions?
Also, could this possibly fix the problems I'm having with stalling on startup?
P.S. Any advice on the prodecures to change the Camshaft Position Sensor and Rear O2 Sensor would be great too. Could anyone tell me where to find each, how difficult they are to change, ect?
Old Aug 11, 2010 | 12:14 PM
99zx2's Avatar
test the sensor first to see if it's getting correct voltage. you can search for a manual on here.
as for the rear o2: use wd-40 or pb blaster on it before you try to take it out. just changed one on our car about two weeks ago. don't be freaked out by the wiring harness going into the car's body just take that rubber thing off and gently pull on the harness until you see the connector come out.
however, you've said that the ecu threw the code for the front sensors. have you replaced those at all? be prepared for a possibility of them coming back after you change the rear one.
Old Aug 11, 2010 | 12:16 PM
Pint07's Avatar
Yeah, I've changed both of the front sensors already. I'm not sure where the rear sensor is exactly though.
I don't have any way of testing the voltage :\
Old Aug 11, 2010 | 12:17 PM
cashoit's Avatar
ECU dont sound bad to me man. Sounds like u have a bad rear o2 sensor and need to test Camshaft position sensor (CPS) per FSM. A bad CPS will def cause misfires and all type of issues.
rear o2 sensor u gonna hafta lift the car. Its downstream of the cat.
THe CPS is a sensor on the engine across from the PS reservoir. Its the only sensor there inserted into the engine. Check sensor for fouling and check harness for damage.
Old Aug 11, 2010 | 12:28 PM
99zx2's Avatar
i didn't lift the car when i did ours lol
it's on the driver's side right after the cat (think driver's door area).
p.s. this guy is selling a cps for $15 shipped. http://forums.maxima.org/4th-generat...-trim-etc.html
Old Aug 11, 2010 | 12:36 PM
Pint07's Avatar
Ooh nice, thanks a ton. That'd be great. How difficult is it to change out the CPS? Tools needed? Any write ups on here?
Old Aug 11, 2010 | 12:47 PM
supergondi's Avatar
your mileage is a testiment to how well these cars are built as for your problems ive had them all and more and in ny we have high emission standards you should just replace your 02 sensors and your cam position sensor with sensors you are 100 percent sure are good but you should clean the idle air contol or for those of us who have a thesaurus iacv its the part by the throttle body that allows a predispositioned amount of air from one side of the throttle body to the other to keep the car running when cold or you come to a stop
Old Aug 11, 2010 | 12:49 PM
cashoit's Avatar
Thats a tight fit man lol
U might need a screwdriver or a wrench, thats about it. Its literally one bolt on the front of the engine near the front valve cover .
Old Aug 11, 2010 | 01:03 PM
njmaxseltd's Avatar
Your ECU is fine.
Never go back to the shop that told you the ECU might be bad just because there was more then just your o2 code.
The CPS (cam position) is what times fuel delivery. Fix that first, clear the error codes and see what comes back. That in itself, may solve some of your issues.
Old Aug 11, 2010 | 01:37 PM
supergondi's Avatar
in total agreeance any shop that says your ecu is bad is just hunting for money ive seen shops say anything to get money one guy tried to tell a girl i know she needed a timing belt on her 4th gen and i said to the guy that might be kind of hard he said he does lots of them and i said hard because there isnt one and he got real nervous
Old Aug 11, 2010 | 02:16 PM
asand1's Avatar
Hard start sounds like a bad ECT to me.
Old Aug 11, 2010 | 06:44 PM
Trini Boom's Avatar
Go to the dealership if CPS is defective and get a 10mm wrench and ew and change it yourself. This does not need a write up as it is self explanatory. Some may say don't go to the dealership for the sensor but imporrtant ones like these, I rather spend the money and be satisfied I got something of high quality.
Old Aug 17, 2010 | 09:55 PM
Pint07's Avatar
Update: Okay, today I changed the CPS. Cleared codes, drove it a bit. Then I start my car back up later and the CEL comes back on. The rear O2 sensor code is gone, and I'm getting codes for the front 2, that I just changed. This is pissing me off. I'm so confused right now.
Old Aug 17, 2010 | 10:50 PM
najee1062's Avatar
I would just like to say.... before buying new o2 sensors, check the o2 sensor fuses located in the in cabin fuse box on the drivers side. this maybe one if the reason why you're having problems. I just read from another post that we do have this fuse.
Old Aug 18, 2010 | 11:31 AM
Pint07's Avatar
Wow. I feel dumb. I checked and there wasn't even a fuse in the O2 sensor spot. I put one in there, cleared the codes, drove around the block, restarted my car, and the light stayed off.
Thank you. So much.
Old Aug 18, 2010 | 12:20 PM
najee1062's Avatar
Thank you. So much.
Glad to have help... and you're not dumb at all, the mechanic is the one dumb. The org rocks
Old Aug 18, 2010 | 07:43 PM
Pint07's Avatar
Well thanks a ton! Passed emissions today. Thank god all that's over.
Old Aug 18, 2010 | 07:53 PM
ColombianMax's Avatar
So... is the CEL still off or did it come back? Congrats on passing emissions, I agree dont go back to that shop!
Old Aug 21, 2010 | 05:50 PM
Pint07's Avatar
The light is still off. I'm still having the stalling problems on start up, but I can deal with that. I'm guessing that's a fuel pressure regulator problem or something like that.
Old Aug 22, 2010 | 12:43 AM
aawesome
HOKUSMAX
Nov 13, 2017 04:34 AM
Huttig2009
Sep 25, 2015 03:31 PM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
