Any oe ground wires on valve cover?
Old Aug 22, 2010 | 03:35 PM
edwardh1's Avatar
i had my front and rear valve cover gaskets replaced cause the rear one was really leaking oil.
are there any factory electrical grounds on the valve covers or intake manifold? all of which were disturbed by this work.
thanks
Old Aug 22, 2010 | 06:39 PM
asand1's Avatar
There are two that attach to the front of the LIM, just right of the injector and below the UIM bolt.
Old Aug 22, 2010 | 07:39 PM
najee1062's Avatar
those two with Phillip screws
Old Aug 23, 2010 | 12:36 PM
edwardh1's Avatar
another ground ?
does the wire/cable off the negative battery terminal have a car body connection point where it goes by the battery bottom, (then it goes to the engine block) ?
Old Aug 23, 2010 | 12:52 PM
najee1062's Avatar
Originally Posted by edwardh1
another ground ?
yes... from the battery to the chassis over the the trans and so forth.
Old Aug 24, 2010 | 11:05 PM
Trini Boom's Avatar
another ground ?
Yes, that terminal is located right above the Crankshaft sensor on the tranny housing.
mvm062
Nov 30, 2020 09:00 AM
03VQMAX
Sep 5, 2015 03:47 PM
