reduced gas mileage 99 maxima
Old Sep 2, 2010 | 11:39 AM
K31J1m0N's Avatar
i put a custom cat back on my car yesterday to eliminate the catalytic converter.didnt touch the downpipe so all o2 sensors are where they should be..i noticed a big drop in gas milage... i have a safc installed so what is a good setting to set the high and low throttle settings across the board...i just put -4% to see if it helps...imma eventually get a wideband but please give some advice someone
Old Sep 2, 2010 | 12:00 PM
K31J1m0N's Avatar
bump
seriously no one can answer this?
Old Sep 2, 2010 | 12:31 PM
LeFrank99's Avatar
Well, i'm not expert but if the custom cat is bigger then specs, let's say 3 inches instead of 2.5 , then i guess it's normal, you're asking more on the engine.
A bit more info would be useful
Old Sep 2, 2010 | 02:30 PM
K31J1m0N's Avatar
Response
Its a 2.5 inch cat back with a 3 inch resonator. I only eliminated the first catalytic converter closest to the back that doesn't have the O2 censor. And when I say decrease gas mileage, I mean significantly like 15 miles to the gallon. How low can I go for the high and low throttle before it's unsafe because I am already doing -4%.
Old Sep 2, 2010 | 04:58 PM
Leo_Koneval's Avatar
Just the catalytic converter? Off the top of my head, I can think of possibly exhaust leaks, or maybe a bad catalytic?
I am not sure what else the exhaust system could do that causes that much of a drop. Unless its clogged or something.
Old Sep 2, 2010 | 07:46 PM
K31J1m0N's Avatar
response
i figured it out...when i put the cat on, my safc was probably over riding the original fuel output and since my exhaust is now completely open i had to restrict fuel so i set the fuel output at hi and low across the board at-6%...a/f ratio is perfect now and im getting way better gas mileage then i was even when i had the original exhaust on...thanx for the feedback everyone
dank4us
34
Jun 10, 2024 03:45 AM
Finkle
Sep 27, 2015 09:53 PM
lux97Max
19
Aug 27, 2015 07:48 PM
Jcof88
Aug 3, 2015 10:43 PM
