hey guys.
Old Sep 5, 2010 | 12:09 AM
dkillahster's Avatar
hey guys.
I know this has nothing to do with my old maxima, but the same stuff may apply to my other car..
So i replaced the motor on my car. But since Everything, and i mean EVERYTHING. is hooked up, plugged in, and good to go.
the engine just spins over and over, but won't attempt to start. All the spark plugs are in, and it just sounds like it isn't making any compression at all.
I'm getting, fuel and fire.
Also, i have a Viper alarm system. do you think my alarm system might have something to do with it? Because i can hit the "remote start" button on the remote, and it will just buzz and flash the red light.
because normally, when you hit the button, it will turn green and start the car. But someone told me. Maybe my alarm system disabled a main relay or something causing the car to not crank. And he said, it's possible, from swapping out that motor to another one may have "set off" the viper alarm.
so i dunno. what do you guys think?
Old Sep 5, 2010 | 01:35 AM
max ride 41's Avatar
i think thread title and question are a fail
Old Sep 5, 2010 | 08:10 AM
all i ask for was some help.. wasn't really going for a topic judgment..
But whatever floats your boat man.
Old Sep 5, 2010 | 08:31 AM
hornepirate's Avatar
can you disable the alarm? i would disable the alarm try to get it to crank then go from there
Old Sep 5, 2010 | 08:34 AM
nelledge's Avatar
"I'm just sayin'..."
Originally Posted by dkillahster
...So i replaced the motor on my car. But since Everything, and i mean EVERYTHING. is hooked up, plugged in, and good to go.
Also, i have a Viper alarm system. do you think my alarm system might have something to do with it? Because i can hit the "remote start" button on the remote, and it will just buzz and flash the red light. because normally, when you hit the button, it will turn green and start the car. But someone told me. Maybe my alarm system disabled a main relay or something causing the car to not crank. And he said, it's possible, from swapping out that motor to another one may have "set off" the viper alarm.
You could always bypass the alarm if you think that's your problem. Personally, with a motor change there are too many variables to ask someone to guess with the limited information given here. I would, however, suggest verifying the obvious big 3. This is probable an easy fix after you find the problem. The hard part is verifying that 'EVERYTHING' really is connected. Could take awhile. Just be patient.
BTW, what kind of vehicle is it. I don't believe you ever stated.
i think thread title... (is) a fail
You really should be more specific according to the forum guidelines. But, I digress.
Old Sep 5, 2010 | 09:31 AM
fixed. i snatched the black box from under the dash... she started up right away. haha.
eh, it was another maxima. with a motor that was flown the buck up. but this had a viper alarm on it. but hey. she starts fine now.
Thanks!
sorry for not mentioning the car cause it seems pretty embarrassing to say that i would leave the org.. then come back.
Old Sep 5, 2010 | 10:07 AM
schmellyfart's Avatar
What happened to the Integra?
Old Sep 5, 2010 | 11:18 AM
i still have it. just got through fixing it cause of a blown motor a few weeks ago.
i found a maxima like 1 week and day ago. $300 with blown motor. lady's son's car.. from florida.
LOL
Old Sep 5, 2010 | 11:46 AM
dontay23's Avatar
please help
hey ia new to maxima.org i have a question i have two maximas one is a 2001 that needs a engine the other is a 1999 .will the engine out of the 1999 fit in the 2001 please help me out both have fourth vin numbers c
Old Sep 5, 2010 | 01:15 PM
Trini Boom's Avatar
I am not going to say that it will not fit but you will have a lot of work to do in order for it to work..
Old Sep 5, 2010 | 02:12 PM
mdkgod43's Avatar
q45 rims
im new on here and i just wanted to know if 2002 q45 rims are ok for 98 maxima they are 245 45 18 and the inner tires goes bad real fast someone told me there to wide but i checked an said i can have up to 7.5 wide so i donno wats the problem maybe tires are to wide?
Old Sep 5, 2010 | 04:04 PM
WTF? why the hell are you people thread jacking?
Old Sep 5, 2010 | 04:11 PM
mdkgod43's Avatar
im jus asking one question dude aint that serious
Old Sep 5, 2010 | 05:24 PM
VQ30MPG's Avatar
I blame the thread title.
Old Sep 5, 2010 | 06:17 PM
mdkgod43's Avatar
can u help me out
Old Sep 5, 2010 | 06:58 PM
please read the forum guidelines people, its not rocket science. i can bet at least 2 of these questions would be covered by doing a simple search. we understand you need help, at least do a quick search b4 you type in a question that has been asked many times allready. kthxbye!!!
HerpDerp1919
Sep 29, 2015 02:02 PM
newtomaxima
Sep 25, 2015 05:16 AM
dcam0326
Sep 18, 2015 04:52 PM
DrVee
Sep 4, 2015 12:18 PM
sdotcarter
Sep 2, 2015 09:53 PM
