'97 gle rear caliper stuck/rusted
Old Sep 9, 2010 | 01:32 PM
Quickywd01's Avatar
Hello, I've rescued a '97 gle and the drivers rear caliper and pads are stuck to the rotor as if though they were glued onto the rotor. The caliper bolts are removed and the caliper/pads will not come off. I tried pb blaster, block of wood, sledge hammer, and pry bar. What should I do? The passenger side is free and not stuck and I have the handbrake handle down/released. Any help is appreciated.
Old Sep 9, 2010 | 02:41 PM
asand1's Avatar
Remove the e-brake lever from the caliper and try to turn the shaft by hand to release the pressure.
Old Sep 9, 2010 | 04:17 PM
JtzMax's Avatar
Whatchyou say?
Yep!
Very common issue with the 4g's.
Old Sep 9, 2010 | 06:36 PM
colombianmaxima's Avatar
damn i had this happen to me before i had to bash the **** outta it and ended up buying a new one , good luck with it
Old Sep 9, 2010 | 08:34 PM
Quickywd01's Avatar
Thanks for the quick help guys. I figured it out with some elbow grease. After driving around the block found the other side is banging around. Guess that's what happens when someone tries to fix stuff but doesn't do it quite right. It's slowly getting there though. Still need to tackle the crankshaft pulley. But we'll need that pulley to spin something.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
ef9
Sep 5, 2015 11:18 PM
