Transmission leak
Old Sep 25, 2010 | 01:26 PM
blocster's Avatar
Transmission leak
My transmission of my 98 Max keeps leaking out of the driver side axle. This happen about five years ago and after replacing the seal then the CV axle I had the transmission rebuilt. Now I replaced the seal twice but I'm thinking it's internal again. Anyone have this problem and if so any advice?
Old Oct 16, 2010 | 09:55 PM
732vqmqx's Avatar
i suggest u make sure the seal is not on backwards or something. the axle seal should leak if its on backwards. good luck
Old Oct 17, 2010 | 09:41 AM
Nealoc187's Avatar
SLOW
differential bearings are bad again. whoever rebuilt it probably didn't shim the differential bearings properly they just put in the same shims that were already in there. this is what happens when you do that, the bearings can fail again prematurely.
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
