Broken window pulley/motor?
Old Oct 2, 2010 | 08:35 AM
95Maxed's Avatar
Hey guys, can anyone help me figure out what I need todo to fix my window problem. Ive linked a video to explain the problem.
Here ya go:
http://www.youtube.com/watch?v=kOsEoG5U3Sg
Old Oct 2, 2010 | 12:53 PM
ef9's Avatar
ef9
I would take the motor and regulator assembly out and see what's going on. I had a similar problem in my I30. The problem I had was a plastic clip broke on the regulator.
Old Oct 2, 2010 | 02:29 PM
95Maxed's Avatar
How hard is it to take out?
Old Oct 2, 2010 | 11:12 PM
ef9's Avatar
ef9
Super easy. You already had the door panel apart, that's the most difficult part.
1. Remove vapor barrier.
2. Lower window enough to remove the two M8 screws (10mm socket would get them out).
3. Remove window from door (if you have vent visors, you can just tape the window up without removing the window from door).
4. Disconnect the power window motor from door harness.
5. Remove M8 screws that hold the motor to the door.
6. Remove M8 screws that hold the regulator to the door.
Old Oct 3, 2010 | 02:57 PM
GGENIUS's Avatar
i had this same problem pretty much in my gle. except my window wouldnt stay up along with your problems. it turned out the bolt that holds the "up" wire in place came off and the wire was disconnected.
Old Oct 3, 2010 | 05:02 PM
Remminator's Avatar
Check all your wiring and grounds, make sure there isn't a lose ground causing intermittent operation.
You could also remove only the motor, I wouldn't remove the regulator unless you absolutely have to as they are a total pita. Once you have the motor out, open it up. Inside you will see a messy combo of grease and the remains of old teflon bushings. clean out the mess, take yourself to autozone and in "help" section you will find a pack of 3 new teflon bushings. Put them back in spaced evenly and repack with bearing grease. voila, working window motor.
Old Oct 3, 2010 | 05:07 PM
95Maxed's Avatar
Hmmmm... I did hear something metal fall in the door panel while I was rolling up the window...
Ill check the grounds when I get a chance. The motor works, it just keeps running if i hold the button even if the window is up.
Old Oct 3, 2010 | 06:12 PM
GGENIUS's Avatar
it was pretty hard for me to get the motor out of my doorshell without removing the regulator. mine was the drivers side door though i dunno.
Old Oct 3, 2010 | 08:48 PM
ef9's Avatar
ef9
The regulator is extremely easy to remove. I removed mine in 10 minutes after the door panel and vapor barrier was removed.
The symptoms the OP mentions sounds like it is a mechanical problem, not an electrical one.
Old Oct 4, 2010 | 10:51 AM
Phromethius's Avatar
SAME issue with my drivers side door. I recently took this apart to fix my door lock, I will post pics later tonight. is it true that if you HEAR the motor working that its probably NOT the motor? Mine just does not stay up, it falls into the door frame, I put a piece of wood in there to keep the window up. This lead me to believe that it was my regulator which seems pretty intensive to remove. Ill photoshop my pictures to illustrate the question too. Maybe it will help original post.
Old Oct 4, 2010 | 02:25 PM
GGENIUS's Avatar
did you read my post? i said i had the same problem youre having, window will not stay up. it was the connection between the motor and the regulator.
Old Oct 4, 2010 | 08:07 PM
ef9's Avatar
ef9
I had the exact same problem on my I30 and my '92 pathfinder.
Both was the same problem, plastic clip in the regulator assembly that holds the window up.
Easy fix for both (fixed the plastic clip with a metal bracket).
If you take your regulator out of the door and take a look at it clearly, you can see how the unit supposed to operate properly and why it's not operating properly.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
