where is terminal 25 on a max? supposed to be a ground
What you need is a picture of the ECU connector. The EC section of the service manual has this.
Download a manual from here: http://www.nicoclub.com/FSM/maxima/
There are a lot of pages that have the ECU connector picture. For example, page EC-307 at the very bottom.
I've seen those diagrams. I just don't know where the connector is on the car. Is it the main plug on the ECU? I need to unplug it and test whatever terminal 25 is on the plug? I know it's a noob question, but... I don't know.
can you confirm FSM 97 EC-91. So If I am testing the MAF, I need to use a wire probe to terminal 25(which is a ground wire) on that plug , with the car running and the plug in the ECM.
So I just stab a probe in the correct wire terminal from the back of the plug, or penetrate the insulation somewhere on terminal 25 wire, and test voltage that way?
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
