Help with codes /monitors please
Old Oct 11, 2010 | 09:40 AM
1997MAXZ's Avatar
I got my regular Knock sensor code P0325
My regular P0440 ( Small evap leak code)
New!! P0446 (evap canister Vent control) code
Also read-- Catalyst MON / inc ???
HTD catalyst/ NA ???
Sec air system/ NA ???
Any input would be appreciated/also how bad do you think this is affecting my car( 97 gle) gas mileage/performance/damage?
Old Oct 11, 2010 | 10:37 AM
1997MAXZ's Avatar
Old Oct 11, 2010 | 02:52 PM
DennisMik's Avatar
The P0446 code, evap canister vent control valve, is the one to address first. This valve is located behind the driver rear wheel (sort of). It has a plunger inside that slides back and forth, but the valve can corrode and prevent the plunger from sliding. Sometimes you can take the valve apart and clean it and sometimes you have to replace it. Fixing this may also fix the P0440 code which is for the electrical control unit for the valve.
The knock sensor code will probably go away too. That code seems to pop up along with every other code that can curse you.
Old Oct 11, 2010 | 03:05 PM
2000_MAXIMA_KING's Avatar
There's a tsb for the evap system on how to clean it, search for the P1447 code and you'll find it.
Old Oct 11, 2010 | 03:13 PM
Also in the tsb it states how to check if everything is functioning properly iirc so that way you can replace whatever is bad.
Old Oct 13, 2010 | 04:38 AM
1997MAXZ's Avatar
I remember a thread naming off all of the orgs abbreviations, does anyone know what it was called. I always have trouble understanding everyone's abbreviations, ( tsb, iirc)?? im losing it. Thanks
Old Oct 13, 2010 | 06:36 AM
99greddymax's Avatar
the knock sensor will give you crappy gas milage.
as far as the monitors, i wouldn't worry about them. Unless you have a smog check coming up.
Old Oct 14, 2010 | 05:58 PM
Trini Boom's Avatar
I am going to assume that you have the AZ check engine computer. Those monitors will not show up for some odd reason or another. P0440 and P0446 are only emissions codes. The P0325 is making you lose performance and gas mileage though.
Old Oct 14, 2010 | 06:09 PM
DennisMik's Avatar
Only if its a real code and not a "ghost" code as I suspect it is in this situation.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
