rear strut problem..help
just bought tokico blue rear struts for my 96
they came with hardware
i installed them
they were good for like 2 days
note ive tried it twice
after 2 days or so they seem to pop through the strut mount
and make a knocking noise? looks as tho the struts really arent doing anything
anyone have this problem?
the first time i took it apart the bottom of the two bushings that came with it slid over the little knotch on the top of the strut
is there a washer that it didnt come with or something?
i installed them
My Illuminas came with the required hardware. If yours didn't come with the washer, double check that you got everything else you should have received. Otherwise, reuse the old washer, etc.
Compare the parts you got all of the parts in the suspension writeup.
http://forums.maxima.org/4th-generat...n-updated.html
In the thread I linked to look at the diagrams in post #4. Part #8 for the rear or part #55248N. It's more like a cup that sits on top of the bumpstop and underneath the bushing. The cup/opening part should be facing down. There should also be another washer (this one actually resembles a washer) that goes in between the upper bushing and the upper strut nut.
Good luck with getting it fixed.
ps. you should be able to reuse the washer and cup thing from your old suspension, if you still have it.
If you can't find the cup like washer, head down to your local hardware store and get yourself a nice size washer to sit on that nub. It should be wider then the upper bushings and fit snug on the shaft on top of the nub.
dvcamp
Sep 18, 2015 10:17 AM
ef9
Sep 5, 2015 11:18 PM
