Car shaking on take off after flywheel and clutch upgrade
Old Oct 22, 2010 | 07:34 PM
maxxxdout's Avatar
Hey guys,
I just changed my clutch to stage 3 and got a fidanza flywheel, and also got a new motor. Since the change when pulling off out of 1st unless i launch from about 2k rpm the car does this shake before it pulls off. Its moving forward as it shakes, but its shaking/jerking, whatever you wanna call it. But its doing it. Why? and what can be done to remedy this issue?
thanks
Old Oct 22, 2010 | 07:41 PM
Goomz's Avatar
maybe your clutch is too harsh for the tranny? stage 3 is a bit much. maybe the clutch is mis aligned too
Old Oct 22, 2010 | 07:44 PM
maxxxdout's Avatar
is there anyway that i would be able to figure this out without them taking the whole thing apart again??
Old Oct 22, 2010 | 07:58 PM
Sinturion's Avatar
N00blargh
What kind of material is the new clutch? ceramic doesn't like to slip much
Old Oct 23, 2010 | 12:10 PM
maxxxdout's Avatar
It's ceramic.. A ceramic 6 puck
Old Oct 23, 2010 | 07:41 PM
DennisMik's Avatar
I put in a stiff clutch on an older car I used to have and it had the same symptom. Turned out I had to upgrade to stiffer motor mounts.
Old Oct 24, 2010 | 01:25 PM
maxxxdout's Avatar
i know i need to get new mounts. when i took it to nissan they said 3 of them were goin bad, but i didnt have this issue before the swap , but im also gettin a p1320 code now too, could that be part of the problem??
Old Oct 24, 2010 | 01:42 PM
DennisMik's Avatar
That's a possibility. According the the FSM, things to check for P1320 are:
* Harness or connectors - (The ignition primary circuit is open or shorted.)
* Power transistor unit built into ignition coil
* Condenser
* Crankshaft position sensor (REF)
* Crankshaft position sensor (REF) circuit
Because of weak motor mounts, the engine is shaking as the clutch is engaging. The clutch plate grabs the flywheel, causes a drag and the engine rocks. With weak/soft motor mounts, the engine rocks more than it should and then bounces back in the other direction. This keeps happening until the clutch is fully engaged.
Maybe the shaking has pulled on some wire harness connector, and maybe the code is just unfortunate timing, unrelated to the clutch situation.
Old Oct 24, 2010 | 07:17 PM
maxxxdout's Avatar
i gotta check it out this week... i saw that post about the p1320 code. ill check it out during the week. Ive already spent a substantial amount of money on this little setup, so i dont want to have to spend any more serious money right now to remedy this issue. But the shaking thing is first priority because unless i damn near launch the car it shakes. But past just pulling off shes a monster. Pulls like a bat outta hell now
Old Oct 24, 2010 | 07:28 PM
QT1 5MT AE's Avatar
Gram Lights addict
are you turbo or sc with 300+ torque? why do u have a stage 3......
this is pretty normal given that stiff clutches grip pretty hard, engagement is pretty much a hit or miss. you'll benefit from ES motor mounts and NWP torque link but it will not make it go away.
Old Oct 24, 2010 | 07:55 PM
maxxxdout's Avatar
not yet, but i plan to. Im gonna go turbo. So since i was swapping the motor i decided to do everything at the same time since it was all gonna be out.
Lakersallday24
Jun 16, 2019 01:35 AM
maxima-junky
Oct 21, 2015 05:17 PM
maxima-junky
Aug 13, 2015 09:59 AM
sc10692
Aug 9, 2015 09:37 AM
