CEL 0901,0307,0503 after sensor replacement
Old Oct 27, 2010 | 12:10 PM
eFLO's Avatar
i was having problems with a faulty o2 sensor, i replaced it cleared the cel but it came back. (0503) returned that sensor and got another new one, just installed it cleared codes and they all came back.
do i have to drive around for a while before they clear? dunno wtf is going on.
Old Oct 27, 2010 | 03:48 PM
eFLO's Avatar
i checked the voltage the sensor was putting out and it was reading in spec according the haynes, which is between .1-.9 volts. im not sure what else to do...is there just a period of time where the ecu has to readjust? anyone else go through this?
gas mileage sux!
Old Oct 27, 2010 | 09:05 PM
Swazey's Avatar
i have a FSM and Haynes in the car but im gonna pass out in a min. ill look up what it says for you in the am but here's what the codes are from just in case you were unsure:
0901 - Front Right Heated O2 sensor heater
0307 - Closed Loop RH Bank
and you gas mileage is gonna b alll f'ed up. Here's all you need to know about O2 sensors: http://www.aa1car.com/library/o2sensor.htm
how did you clear the CEL?
Old Oct 28, 2010 | 07:33 AM
eFLO's Avatar
i know what the codes mean, i'm just baffled as ive changed the sensor twice and codes are still popping up. i cleared the code using the ecu method, turning the screw and whatnot.
Old Oct 28, 2010 | 08:42 AM
Swazey's Avatar
did you test the sensora to make sure they were not faulty? check the wires going to the sensor as well.
Old Oct 28, 2010 | 08:48 AM
eFLO's Avatar
the harness is getting power. and the sensor is giving a reading within spec like i mentioned. the only thing i can think of is that it needs a certain amount of miles to readjust.
Old Oct 28, 2010 | 08:50 AM
ctsnyper's Avatar
When I unplug and plug back in my MAF sensor, the CEL comes on for a while. Couldn't these 2 problems be part of a re-learning process by the computer?
Old Oct 28, 2010 | 04:48 PM
eFLO's Avatar
i hope...i have no other ideas.
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
