NOS electrical hook up, give me a hand
Hey everyone,
Well, I'm installing the electrical stuff on my NOS 50 shot. I connected all the junk, and then it came time to turn on the car. Well, some fuses blew in the fusebox, not the fuse on the orange wire to the battery, just some fuses. I think I made the mistake by trying to get the Accesory power from splicing it with the accsaory wire on the cigarette lighter. Damn, I think that messed it up, but it was extremely cold and dark outside. So after I replace the fuses, where should I get the accesory power from? The fusebox? If so, which colored wire is it????
i got mine from the fuse box.. but i had a simular problem you had.. i guess by the time i put the center console i had a wire that was touching the frame of the center console.. so one day when i had some patience.. i took it apart.. spliced new wires.. soildered properly and taped them up properly.. and now its fine..
SprintMax,
Thanks for the tip, how did u find the wire? I think that I'm going to use a test light, but if you know the color of the wire that would be of great help. Thanks. Also, I have the red toggle switch, and there are two terminals on it. I connect the 12+power to one terminal, and the accesory power to the other, correct? If I'm right, then you don't have to ground this because there is no light on it. Thanks
i took the positive wire from the cigarette lighter..
if its for NOS you need a 3 pin toggle switch.. you do need ground.. and i had a switch with my kit..
Originally posted by shaftcube
SprintMax,
SprintMax,
Damn, that's weird, I must of done something wrong, now I have the blue switch connected, the one that came with the kit, but I ordered the NOS one w/the red guard over the toggle switch. Anyways, now I have the blue switch on, and I got the accesory power by splicing into the orange power wire and connecting that to the switch. When I turned it, the fuses shorted. Everything else, all the other electrical stuff is grounded and hooked up, just this damn switch, and I want to get my NOS connected. Any suggestions? Thanks
what fuse are you shorting out?
well I haven't had the chance to check it yet, but there was a decent sized flash, it was dark and cold and I was pretty annoyed, I'll have to check the fuse when I get home. Where did you ground your wire for the switch? And you did splice the wire from the cigarette lighter?
the red toggle switch I ordered from NOS only has 2 terminals, I called the tech line, the guy said that one wire is for the 12v power, the other is for the accesory wire, he said that u dont need to ground it
i took both terminals from the cigarette lighter.. power and ground.. and tap wires off them.. i am using them for NOS Activation switch, Bottle Heater Switch, FP Gauge, EGT Gauge, NOS RPM Switch.. after i did my clean install with time to think.. i stopped popping fuses
& as for a ground, (if you use the red covered toggle - no ground) you can ground it any where that is easy to get to & closed the the relay.
it is better to tap power from the fuse box & run the nos system fuse(s) independant from other accessories if possible. this is good for 2 reasons (1) easy to diagnos if it is a problem with your nos sys. or sys. in vehicle (2) not as much amperage draw in that one circuit that can cause fuses to blow.
Sprint,
Have you had any trouble with the NOS electrical system as it is through the cigarette lighter (fuses blowing or anything??)
Sprint,
Thanks for the info, do you remember which colored wire you used from the back of the fuse box?
you can either get a connector that pops into the open terminal & intall a fuse to compete the ciruit (best)
install a fuse & use a fuse tap (easiest way)
or tap right into the wiring behind the fuse box
Originally posted by 99NosMax
there are open/unused terminals in your fuse box that are hot, you can tap off of any one.
Unclejunebug
Apr 2, 2016 05:42 AM
