Hard to turn the ignition.
Old Nov 21, 2010 | 05:48 AM
shook187's Avatar
I'm having a problem getting the ignition to turn. I have to wiggle the key and even that sometimes doesn't help.
I'm sure its not the key casue I've used my other keys and it still has the same problems.
Old Nov 21, 2010 | 06:54 AM
Dave H.'s Avatar
Is the steering wheel locked when this happens? If the wheel is locked, the key won't turn. Move the steering wheel to unlock it, then the key will turn.
If that's not it, you may need to replace the ignition switch.
Old Nov 21, 2010 | 07:04 AM
chrome91's Avatar
yeah it could be the steering wheel lock, with your left hand gently hold the steering wheel to the left or right, whichever feels the most free and then with your right hand turn the key and it should be easier
Old Nov 21, 2010 | 07:48 AM
How many miles do you have? If you haven't changed your ignition switch yet, it's probably about that time.
Old Nov 21, 2010 | 10:01 AM
shook187's Avatar
The car has 170k miles and the streeing wheel isn't locked :-(
Old Nov 21, 2010 | 10:04 AM
Dave H.'s Avatar
Then change the ignition switch which is very easy to do.
http://www.youtube.com/watch?v=4ykT9uCJXSY
Old Nov 21, 2010 | 01:12 PM
DennisMik's Avatar
The stiffness in turning the key could also be the lock cylinder itself. Before you run out and buy another ignition switch, take it off and try turning the key.
Old Nov 22, 2010 | 05:56 AM
shook187's Avatar
How is this done?
Old Nov 22, 2010 | 06:34 AM
jholley's Avatar
The ignition switch slides into the back of the lock cylinder
If you need to replace the lock cylinder read this thread
http://forums.maxima.org/4th-generat...placement.html
Old Nov 22, 2010 | 06:47 AM
Swazey's Avatar
the cylinder is probably on its way out. is there a lot of play when the key is in the ignition?
you can get a new tumbler. it is very easy to install.
someone "attempted" to steal my car and punched the ignition. they couldn't get it to start, thank god. i got a new tumbler and had a locksmith match the tumbler to my original keys so i was not walking around with 2 sets of keys. it cost me $100 to get the tumbler matched to the keys.
heres a pic of what you will need:
Old Nov 22, 2010 | 12:51 PM
DennisMik's Avatar
watch this video on how to remove the ignition switch. It's pretty easy.
http://www.youtube.com/watch?v=4ykT9...C2C64F&index=3
Just be careful when you are taking the screws out of the ignition switch as there are exposed wire connections that are live. Or you can unplug the ignition switch before taking out the screws.
bryants95max
Oct 2, 2015 12:52 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
LtLeary
Sep 14, 2015 12:33 PM
trungg86
Sep 4, 2015 04:58 AM
