Rough Idling..
Old Nov 21, 2010 | 06:41 PM
Imagination's Avatar
Rough Idling..
I have read and read thru many posts (some were quite interesting, some real authors out there), but I still couldn't find a post that I haven't tried to fix my problem.
First, the statistics:
96 Max GXE
Automatic
333K Miles
No CEL light
Problem:
When the car turns on (having problems with the car starting and turning over multiple times before starting another issue) it has a strong hesitation/vibration. At lights it feels like it wants to just cut off. I thought it was just water in the gas (similar symptons), but after 2 bottles of HEET the issue is still there.
Changes:
So this is what I have changed:
- Camshaft and both crankshaft sensors (tested them all and they were fine, but replaced anywhere..thought this was causing the starting problem)
- Replaced all the spark plugs, and checked all the coil packs (everything tested within limits)
- Replaced the fuel filter
- Changed the oil, filter, and oil pressure switch (looked like it was leaking)
- Cleaned the TB
Open to ideas/suggestions.
Old Nov 21, 2010 | 09:40 PM
TreizeRXH's Avatar
Fuel pump??
Old Nov 21, 2010 | 11:38 PM
silencecalls's Avatar
Offtopic, but holy schnitzel!! 333k miles!!! Pictureeees please.
Old Nov 21, 2010 | 11:44 PM
schmellyfart's Avatar
I would check the IACV and MAF and check for vacuum leaks around the intake and intake manifold.
Old Nov 22, 2010 | 04:57 AM
I eliminated the fuel pump because there are no issues during acceleration. If it was constant then I would have checked the fuel pump.
I will check the vaccum connections, that is a good idea. Any good write-ups on the IACV/MAF? I tried a link one time, but they all returned to the same page.
Old Nov 22, 2010 | 08:20 PM
Stagnet04's Avatar
EGR valve. I have a similar issue and have done everything you have done plus more. I have narrowed it down to the EGR valve which I will be changing within a week. I cleaned the EGR tube and it was completely clogged up so this is the next step. If you do some research, youll find that a bad EGR valve will give you the exact same issues.... just a suggestion though, im anxious to find out what your issue is, so keep us updated....
Old Nov 27, 2010 | 11:04 PM
hatchexhaust's Avatar
Ya i am with stangnet. when was the last time u had the egr tube off for a good cleaning? If its complety pluged cause of your problem most likely? and no cel is the tell-tail. b/c the egr will not set codes.
dank4us
34
Jun 10, 2024 03:45 AM
litch
123
Jan 4, 2024 07:01 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
conansriver
Sep 11, 2015 10:26 AM
ballerchris510
Sep 10, 2015 09:35 PM
