Startup Trouble?
Old Dec 18, 2001 | 11:15 PM
krzymax's Avatar
Maxima owner since 2000
Startup Trouble?
This morning after leaving the car in the garage all night, i put the key in the ignition, turn it to the on position and hear it grind for about 3 seconds before the engine actually starts. i turn the engine off and attempt it again and the car starts normally. after 8 hours of work, i start the engine again and it takes forever after the griding sound for it to start. there must be something wrong with my car. is it the spark plugs?
Old Dec 18, 2001 | 11:26 PM
Mr. Nismo's Avatar
Sounds like you may need a new starter.
Old Dec 18, 2001 | 11:38 PM
Nismo's Avatar
it could be that the teeth on the starter are worn out
Old Dec 19, 2001 | 12:01 AM
krzymax's Avatar
what does the starter look like? how do i change it? how much does it cost? thanks in advance. i am very car illiterate
Old Dec 19, 2001 | 12:28 AM
Nismo's Avatar
its an electric motor thats mounted next to your flywheel/torque converter which engages the teeth on the flywheel and thats what turns it over. not too shure on the price though.
Old Dec 19, 2001 | 02:15 AM
Stillen_I30's Avatar
This tells you how to fix the starter, but thats good enough to let you know how to replace it. An online shop manual says the starter costs about 250, but can be had for around 180 or less if you look around on the net (for a new one).
http://www.motorvate.ca/auto/maxima/starter/starter.htm
Old Dec 19, 2001 | 08:29 AM
98sterlingmist's Avatar
$299 + tax for dealer install and that is for a refurbished starter not new. Had mine replaced on my 98 at 40K. It made the same noise yours is making.
It is kind of a pain to do on your own unless you know what you are doing.
Old Dec 19, 2001 | 11:14 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
Re: Startup Trouble?
if you bring it to my place we'll look at it for you and figure if its really the starter then we can do it for you also. itll be cheaper then a shop and you get full waranty...PLUS, you get to check out TurboMax...haha
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
