5 speed swap ECU Question?
Old Dec 20, 2010 | 12:53 PM
mpvibes's Avatar
I recently completed my 5 speed swap, but car tends to have high idle only when I come to a stop. I have a 98 maxima with a 97 5 speed manual transmission running on a 98 auto ECU, I have a 95 manual ECU in storage. Should I use the 95 manual ECU or should I get a 97 or 98 manual ECU? Also, will the car run better or the same with a 95 manual ECU compared to a 97-98?
Old Dec 20, 2010 | 02:38 PM
shift_5's Avatar
let me know if you decide you want to sell the 95 MT ECU!
Old Dec 20, 2010 | 02:43 PM
shift_5's Avatar
BTW, I think you will get a few check engine lights with the 95 ECU. But I would run a manual ECU if I were you. Less problems.
Old Dec 20, 2010 | 05:44 PM
mpvibes's Avatar
Ok, thx. Do you need a 95 manual 5 speed ECU? I will trade you if you have a 97-98 5 speed manual ecu.
Old Dec 20, 2010 | 05:45 PM
schmellyfart's Avatar
OP said he already has one in storage.
Old Dec 20, 2010 | 06:25 PM
mpvibes's Avatar
Will my car drive retarded with a 95 manual ecu? Anybody?
Old Dec 20, 2010 | 07:16 PM
essential1's Avatar
My axles cry for mercy...
No he wont. He will actually have less check engine lights than with a newer ECU.
If the ECU is working fine, the car will drive fine.
Old Dec 20, 2010 | 09:02 PM
shift_5's Avatar
I don't. sorry. but let me know if you want to sell the 95
Old Dec 21, 2010 | 04:44 AM
mpvibes's Avatar
Ok, I will let you know. I'm going to the junk yard today. Last time I checked I found a 97 maxima 5 speed. Hopefully, the ECU is still their and no one took it.
Old Dec 21, 2010 | 03:15 PM
mpvibes's Avatar
Alright, I got the 5 speed manual ecu from a 97 maxima at the junkyard. My only question is, the ECU that I pulled out on this vehicle had J2 @ the top? The one that I pulled from the 95 5 speed had MT @ the top? Does every ECU have different letters and numbers @ the top? In other words, how can you tell if it's truly a 5 speed ECU?
Old Dec 24, 2010 | 09:28 AM
shift_5's Avatar
Look at the OEM numbers on it and find the link for the ECU ID, I think it is a sticky. It doesn't have all the numbers on it, but you might be able to find it on there.
Old Dec 24, 2010 | 07:30 PM
mpvibes's Avatar
Ok, thx shift 5. I'll check it out.
maxima-junky
Oct 21, 2015 05:17 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
ef9
Aug 27, 2015 10:17 AM
TurboA32
Aug 27, 2015 08:44 AM
ffcbairn
Aug 16, 2015 09:29 PM
