Idle Issue???
Old Jan 1, 2011 | 10:19 PM
sspomonag's Avatar
Idle Issue???
So i think i have a problem. After i cleaned my Tb and Iacv i felt like my idle might have went up. It wasnt loud like it is now when i turn on the car. And everytime i turn it on if its not warm it idle's at 1500 and slowly drops down. My mileage on the gas is horrible i have to put 15 dollars every other day and i only use the car for street purposes only. Im leaning on a knock sensor Problem i need some info about this Thanks
Heres the link to the video
http://www.youtube.com/watch?v=YbEKqd9vX4o
Old Jan 1, 2011 | 11:28 PM
1500rpms is where it's supposed to idle at when it's cold. Mine does the same.
How's the idle at a stop light when the car is warm?
Old Jan 1, 2011 | 11:30 PM
MaximaSpd85's Avatar
if you feel that the idle isnt where its suppose to be adjust it by turning the black plastic screw on top of the iacv.
Old Jan 1, 2011 | 11:31 PM
chrome91's Avatar
on a cold start thats what its supposed to idle, it should should start around 1500, then a couple seconds later creep down to around 1200ish and then a few seconds later to normal idle
if youre idling at 1500 stopped when the car is warm thats a problem, if thats the case you can adjust the idle
Old Jan 2, 2011 | 12:08 AM
sspomonag's Avatar
Great thanks.. But im still thinking i have the ks problem because of the gas and how when i press the gas pedal it hesitates and then it pull with power.
Old Jan 2, 2011 | 12:09 AM
max ride 41's Avatar
my idle sits at 1000 rpm's when warming up and 500 when she's good and warm. never heard of 1500 before, thats high.
Old Jan 2, 2011 | 12:11 AM
sspomonag's Avatar
c thats how it used to be before. Now i think that its really high. How do i adjust the *** on the iacv? i kno u turn it but what way and does car need to bee off ???
Old Jan 2, 2011 | 09:08 AM
VQ'rInWLA's Avatar
Tighten to drop it. You can adjust it while its idling.
I can check for a knock sensor code for you at the meet. They dont trip an SES light.
Old Jan 2, 2011 | 09:24 AM
Wrong. Your TB/IACV probably needs a cleaning to bring it back to normal.
It's normal! But if you really want to adjust the IACV, turn the car on and turn that screw to the right, it'll lower the idle.
Old Jan 2, 2011 | 12:23 PM
luke95gxe's Avatar
op u cleaned every thing that was gunked up an now ur car is doing what it is supposed to do u could adjust it if u want thats a personal decision
Old Jan 2, 2011 | 04:04 PM
sspomonag's Avatar
Perfect today i woke up and i cleaned the T/B and IACV again and Idle is perfect. The car runs fine but ill wait till the meet so dough can check the knock sensor. I don't think any more adjustments need to be made as in messing with the **** in the IACV. Thanks a lot fellow orgers. Pleased to be in a community that is very helpful.
captchaos
Mar 15, 2016 12:18 PM
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
ballerchris510
Sep 10, 2015 09:35 PM
