Manual BLOWER/FAN voltage = 0v
Old Jan 5, 2011 | 10:46 AM
oVeRdOsE's Avatar
Hi,
I took 1 hour in the search section, no result.
I changed the ignition switch (white barrel) and the fan stop working.
1# Booth 15A checked/swapped
2# Connections checked
3# resistor is new ( anyway, it should work on 4)
--- I plugged a voltmeter on the motor connections : I have 0v on ing2. If I play with the selector (1-2-3-4), the voltage goes around 1v and drop back to 0.
--- But, the box that make the air goes to your face or feet, still working.
I have the Haynes electric diagram, and I cant figure where is the relay. if there's one...
Whats next?
Old Jan 5, 2011 | 08:48 PM
oVeRdOsE's Avatar
The relay is NOT there...
Old Jan 5, 2011 | 08:51 PM
Maxima_Joe's Avatar
4th Gen Parts King
The blower motor relay is 1 of the 3 blue relays in the interior fuse box. IIRC it's the bottom one.
Old Jan 5, 2011 | 09:00 PM
oVeRdOsE's Avatar
Nice, I think is all I need, I thought it was the flashers one.
Pretty sure this is my problem.
Thank you
Old Jan 7, 2011 | 12:56 PM
oVeRdOsE's Avatar
4# Relay changed
5# Selector(1-2-3-4) checked
What is the problem?!?
Is there a other relay/fuse under the hood? I checked everything...
Old Jan 28, 2011 | 10:11 AM
oVeRdOsE's Avatar
[FIXED]
The hayness was wrong.( if you look the ignition switch plug straight). They use the car harness instead of the switch, witch they mean.
On the ignition switch theres 6 pins.
1 3 5
6 2 4
They inverse column 1 and 3 so the real thing is (if you take the white ignition plug, and not the car harness) :
5 3 1
4 2 6
Acc : 1 - 2
ON : 1 - 2 -3- 4
Start : 1 - 3 - 5 - 6
I dont remember but I think that pin 4 is ONLY for the blower power Witch mine was defective.
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
