Crank position center wire, below oil filter
Old Jan 14, 2011 | 11:14 AM
pavelsmax's Avatar
Hey guys,
Changed my oil in the freezing cold last night and realized the wire that runs below the oil filter leading to the crank position center was stripped open and showing exposed wiring. I've always noticed while changing the oil that when you remove the filter the oil runs right down on to this wire. I assume after doing a few oil changes with the oil heated up I've melted the rubber around this wire. It was too cold to mess with replacing it last night so I simply threw some electrical tape on there and will attack it another day.
Has anyone else noticed this? I'm planning on cutting out the melted section and splicing some new wire in there. What problems could arise from this wire getting wet if any?
I'll likely reroute the wire when I repair it to prevent the problem of oil from the filter draining onto it.
Old Jan 14, 2011 | 06:03 PM
DennisMik's Avatar
Between my leaking valve cover and changing oil, that wire is always dripping oil. But the wire still looks good and has all the insulation on it.
Old Jan 14, 2011 | 06:36 PM
Nopike's Avatar
That's probably the shield wire or the ground. Just clean it up a little and wrap it with some electrical tape and you are good to go. Unless you are having problems I would not even mess with it untill spring.
I doubt it melted or anything like that it's just the shield wire is exposed a bit, not unusual. Don't replace the shield wire, that will cause problems.
Old Jan 17, 2011 | 08:45 AM
pavelsmax's Avatar
Ok cool thanks for the input
Old Jan 17, 2011 | 10:08 AM
defiance's Avatar
Pretty much what the other guys said, if it aint broke "yet" don't fix it.
mvm062
Nov 30, 2020 09:00 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
