Strut removal problem.
Old Jan 14, 2011 | 12:01 PM
americanclassicg's Avatar
Im trying to replace the strut mounts/bearings on my '95. The two lower bolts will not come loose. Ive tried the pipe trick (ended up rounding the bolt a little, but not terribly), and eventually dug out the impact wrench. It wont budge with the impact gun at 150 psi, from either the bolt or nut side.
Anything I might be missing? Ive got it sprayed with a coating of PB Blaster at the moment, and will probably try again in an hour or so.
Thanks.
Old Jan 14, 2011 | 12:41 PM
rocketrich's Avatar
Two suggestions for you:
1) Heat. Get a torch and carefully try to heat up the pieces to help break them loose. Obviously don't start a fire!
2) When all else fails, get a dremel tool with aluminum oxide cutoff wheel, and cut into the bolts. Sometimes a small slot cut into the bolt will allow you to use a chisel to break the bolt off. But, this is obviously an extreme method. Good luck. Rich
Old Jan 14, 2011 | 12:46 PM
jholley's Avatar
Raise the LCA with the hydraulic jack to relieve some of the pressure.
Old Jan 14, 2011 | 01:13 PM
96nismoSE's Avatar
just cut them off and replace them. theyre cheap enough
Old Jan 14, 2011 | 01:21 PM
njmaxseltd's Avatar
Heat is your friend.
Use a 6 point impact socket on the NUT side, not the bolt.
On a side note, make sure both front wheels are off the ground when you try to remove the strut, otherwise you'll be fighting the sway bar.
Old Jan 14, 2011 | 01:39 PM
RA030726's Avatar
I'm nutty for Nissans
Cranking the incoming air to anything over 90 psi does not make your **** *** 100 ft/lb campbell hausfeld impact gun more powerful.
Old Jan 14, 2011 | 02:17 PM
nelledge's Avatar
"I'm just sayin'..."
.... but nicer.
Old Jan 14, 2011 | 05:55 PM
DennisMik's Avatar
Old Jan 15, 2011 | 06:25 AM
dub maxi's Avatar
Try it. It might help
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
