power seat and windows problem
hi i have a 96 maxima the power windows and the driver seat stop working i search for similar problems and found to check for fuse #18 and # 13 and they are not blown also i i remove the door panel and all the cables are conected correctly so what else could it be ?
ok i check the fuses under the hood and one of the 30 amp fuses is blown so i replace it and the doors and driver seat started to work but not the windows is there something else that i have to check ?
well i remove the battery to clean it out and after i put it back the windows started working so i thing it only need it to reset after i fix the fuse cause after i remove the battery and put it back everything started working ,
thanks for all.
thanks for all.
vingodine
45
May 21, 2016 12:46 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
kjm900r
Aug 5, 2015 07:14 AM
