Heat Problem with Digital Climate
Old Feb 8, 2011 | 05:52 PM
Trini Boom's Avatar
Ok org, here's my rundown. This is from the recent maxima I acquired the end of last year. I have noticed that when the car reaches full warmth, it barely blows in strong heat when set to 85 degrees. This is what I have done so far.
- Replaced thermostat with OEM (because lower hose was cold after warm up)
- Bleed the system for 20 minutes on an incline while raising RPM (after replacing thermostat)
I also followed the FSM diagnostic tool for the digital climate and got the following:
- (25) flashes twice
- Only getting temperature from 2 sensors
This leaves me with two options:
1) Either there is still air in the system and it needs to be bleed out more.
2) The heater core is partially clogged (the top hose is hotter than one at the bottom).
What do you guys suggest I do?? Keep in mind that it is in the teens here in NYC and I am using a workshop to do the work and not a garage loaded with tools. Any help appreciated!
Old Feb 8, 2011 | 06:03 PM
Idrivea98Maxima's Avatar
bump. same problem.
Old Feb 8, 2011 | 06:05 PM
GGENIUS's Avatar
nice bump
Old Feb 9, 2011 | 07:54 AM
njmaxseltd's Avatar
All the sensors in the system need to be working and giving correct readings in order for the climate control to work correctly.
Old Feb 9, 2011 | 07:55 AM
bobflood's Avatar
What are the flashes telling you?? If the system is not getting a reading, or is getting an erroneous reading, from the temp sensor inside the car, it may think it's already warm.
Old Feb 9, 2011 | 11:29 AM
cashoit's Avatar
digital climate...
Did u really flush system good? Maybe bad heater coil or if u gettn codes then u have to replace sensors. I dont think its the heater core.
Old Feb 9, 2011 | 07:39 PM
Trini Boom's Avatar
Well I did back the diagnostic this morning bright and early around 10AM and it came back with "20" which means all the sensors are good. Very weird.. How many temperature readings are you suppose to get? Do you get one from the sunload sensor?
"25" points to the sunload sensor but as stated above, I redid the test bright and early and it came back clean. The sensor in the car functions fine actually and I di see it fluctuate.
Originally Posted by cashoit
digital climate...
Well, after trying to gather more information on this system, I was told that I still have air in the system after bleeding it twice for two half hours on separate days. Reason they say I have air is because when I drive, I get heat and when I come to a stop, it comes in cold. Is the only way to flush this system is to leave it up to 85 degrees on an incline and just keep filling the radiator while revving the engine? Because when the fans do cut off, the thermostat closes which in turn overflows the radiator and coolant coming out until it opens back.
Old Feb 9, 2011 | 08:10 PM
Trini Boom's Avatar
Also, if someone can be very generous and help me by posting a pic of their "water ****" is fully opened when the heat is turned on...because I am wondering if mine is opening fully or not. The FSM doesn't give a good clear pic.
Old Feb 10, 2011 | 08:04 AM
bobflood's Avatar
Because when the fans do cut off, the thermostat closes which in turn overflows the radiator and coolant coming out until it opens back.[/quote]
Unplug the fans while you are bleeding the system.
Old Feb 10, 2011 | 06:04 PM
Trini Boom's Avatar
Well I decided to take a pic of the water valve for you guys because I think that's where my problem is. This is with the car on with heat at 85 degrees.
Now I can't tell if its opened fully or that spring is messed up.
Old Feb 11, 2011 | 05:31 AM
Trini Boom's Avatar
Bump!
Old Feb 11, 2011 | 07:46 AM
njmaxseltd's Avatar
Turn the heat all the way down, does the valve move?
Yes = It's working
No = Troubleshoot
Old Feb 11, 2011 | 08:00 AM
Trini Boom's Avatar
Yes = It's working
No = Troubleshoot
Yes it does move so I guess this rules out that I have a partially clogged heater core? Should I disconnect the hoses from the engine side and use an air compressor or just take it to the dealership and pay the $175 to flush the system properly?
Old Feb 14, 2011 | 10:31 AM
Trini Boom's Avatar
Just wanted to update you guys. I woke up early this morning and disconnected the hoses going to and from the heater core at the engine side and blew compressed air into it. I also bought a bottle of vinegar and poured it into the hoses on both ends and flushing vice versa. Connected everything back and the heat is working now. I am going to monitor if it is consistent and also that I don't have any leaks inside on the floor.
Old Jan 4, 2012 | 12:59 PM
Trini Boom's Avatar
Reviving my thread as heat is back to coming in very weak. I took it to the dealer last month to have the coolant flush which was a deal they had going ($150). After they did the flush, the heat worked for two weeks. Yesterday, I had it set for 85 on high fan speed and it took just over an hour to get real heat coming out. How can I verify that the heater core is the problem?
Also, the car has been idling rough at stops. Not sure if they two are linked.
captchaos
Mar 15, 2016 12:18 PM
mikeg75
Nov 30, 2015 05:12 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
mix master
Sep 7, 2015 08:28 PM
