Low power until 3k rpm and then it takes off.. What's going on?????
98 5 spd.. As the title states.. There seems to be low throttle response until the tach hits 3k rpm.. And then it will take off like a rocket. No CEL. And it's not a misfire I don't think.. I know what that feels like. And after 3k it is super smooth.. I just did my y pipe a few weeks back and the mechanic said one of my o2 sensors could stand to be replaced. I have new plugs, new coils, k&n air filter, and I change the oil with mobil 1 synthetic. What could possibly be the problem??
I'm getting this issues as well. I do have a new ks and plugs so I'm looking at the MAF and TB and see what happens. I'm also getting a heavy stumble here and there when the engine is hot. Not constant though. I also wonder if the stumble I get might have to do with a coil going bad but I'm not throwing codes for anything of the sort.
its a fuel efficiency thing... the ecu is programmed to do that. all max's do that. yours may be worse if your sensors are bad or dirty, but we all have it... not many people on normal driving go about 3k so its where they have cut fuel or timing to be more efficient...
if im wrong, someone correct me please...
Red box = VTEC YO!!
Box starts @ 3k and ends @ 3.5k
ok well i still havent gotten around to the cleaning and everything because of the weather.. however i do have a bad o2 sensor.. i will be replacing both of those tomorrow. aackshun i see your graph but in my case its not just a simple seem in drop in power as much as a hesitation.. its almost as if its not getting fuel or something.. but like i said i do have a bad o2 sensor, but would that cause that big of an issue????
and maxxxdout, you may be feeling it more than the rest of us because your ecu may be adjusting even more because the o2 sensor but we all feel the same hesitation. I can be WOT on a 2nd gear low rpm pull and i wont start moving until the noted 3k-3.5k rpm mark.
if youve got the money to toss around you could always get a tuner, be it a jwt ecu, emange ultimate, or one of the AFC tuners and adjust to your MPG Degrading pleasure! I know I will be soon! lol
EDIT!: just noticed your other thread you posted in again today... you should have already known that this hesitation was created by the ecu! lol the other guys said it too! but i reiterated it for ya! lol gotta get a tuner!
, I'm about to change it as soon as the 6th gen brakes go on anyways.link to original
lol, hes tryen to be JDM yo! its just a mirror image...
O2 sensors have NOTHING to do with how the car runs.... It's purely emissions stuff. If I had hesitation, I would do the Maf, and clean the injectors some how, after changing the fuel filter, then check the plugs. If I still have hesitation, then it is more serious, like Coils, Cam/Crank Sensors, etc.
Dammit, you caught me, damn near 8 months later, I thought I could get away with this sig forever
link to original
JDM Clutch = JDM car y0
i still have yet to clean the iacv but i did seafoam it about 3 weeks ago...
