basic tune up
Old Mar 3, 2011 | 07:27 PM
akbarrasheed's Avatar
basic tune up
Hey ya'll,
I'm getting a tune up on my max 97 141,000 miles. What kind of spark plugs, air filter, and fuel filter do you recommend?
Old Mar 3, 2011 | 07:30 PM
tigersharkdude's Avatar
Originally Posted by akbarrasheed
Hey ya'll,
Seriously, did you not even attempt to search? This info. has been cover a billion times
MaximaSpd85's Avatar
NGK vpowers, or if u wanna go platinums u can go for those too. Air filter- just go with purolator or whatever your parts store has if youre not looking for anything "performance" oriented. same with the fuel filter, although many go with the larger z32 filter.
Old Mar 3, 2011 | 07:44 PM
maximized98's Avatar
Addicted to the Org
Since the car is old, I would get the cheapest stuff you can find.
Spark Plugs - Autolite
Air Filter -STP (or you can beat it against something to get dirt out and reuse)
Fuel Filter - Any
Old Mar 3, 2011 | 08:25 PM
FallenOne's Avatar
Fuel Filter - Any
Wow, thats some advice there... His Max is just a baby.
Actually are those Vpower Plugs any good? Their 3$ Vs. the stock Plugs at 8$
Old Mar 3, 2011 | 08:34 PM
NGK all day, everyday, to the day I die
Old Mar 3, 2011 | 08:39 PM
asand1's Avatar
+1 on NGK. Copper,V power, platinum, iridium, doesnt matter as long as its NGK.
Old Mar 3, 2011 | 08:47 PM
FallenOne's Avatar
Ive always just used the OEM plugs. Mine are around 100K old now though.. Soo I need new ones.
Nissan put NGK's in for a reason i know this.
For instance ive heard of Multiple instances in which Bosch plugs have casued wonderful issues.
Also... There are stipulations on what plugs to use... for instance the Coppers are best for FI since the copper is softer and will burn off if you were to knock Hard.
Old Mar 3, 2011 | 09:06 PM
Ambitionz's Avatar
where to buy the the larger z32
Old Mar 3, 2011 | 09:09 PM
parts store...
Old Mar 3, 2011 | 09:47 PM
Bobo's Avatar
I realize that we are here to help one another, but you have been able to access this website for almost 8 years and you come on now and ask this type of question, give your head a shake!
As others have said below, stick with NGK plugs. I replaced mine with the OEM laser platinum plugs and couldn't be bothered with the V-power copper plugs.
Get a compatible air filter and fuel filter at your local parts store.
What is the condition is the tranny fluid, power steering fluid and radiator coolant?
When was the last time visual checks were made of belts, hoses, exhaust, steering, CV boots, brakes etc?
Hey ya'll,
Old Mar 3, 2011 | 10:46 PM
J2songz's Avatar
second this
Old Mar 3, 2011 | 10:58 PM
silencecalls's Avatar
Use NGK or use nothing!
There was a thread here a little while back where it was very much proved that using non NGK plugs is just plain wrong, not to mention lead to a _decrease_ in performance!
So, plugs are cheap enough as it is - spend the extra money and save yourself the headache.
Old Mar 3, 2011 | 11:29 PM
FallenOne's Avatar
Wow all this out of Me asking if those NGK V-Powers are any good? Also those arent copper are they???
Old Mar 4, 2011 | 06:39 AM
cashoit's Avatar
I must have been lucky, I caught my NGK plats onsale from autozone. $3 a piece
Old Mar 4, 2011 | 06:57 AM
luke95gxe's Avatar
thats where i got mine paid the same
Old Mar 4, 2011 | 07:34 AM
Bobo's Avatar
[I question whether those are the OEM laser platinum plugs.
QUOTE=cashoit;7956744]I must have been lucky, I caught my NGK plats onsale from autozone. $3 a piece[/QUOTE]
Old Mar 4, 2011 | 11:36 AM
FallenOne's Avatar
[/QUOTE]
I highly doubt it.
And yes thats what it is ive been using the Laser's thank you for te reminder.
Old Mar 4, 2011 | 01:21 PM
Bobo's Avatar
What is the part number you got?
Is the part # you got PFR5G-11? That is the OEM laser platinum plug which runs $12.06 on NGK.com.
I strongly suspect you got the BKR5EGP plug which is the GP platinum plug and runs $3.15 on NGK.com. This is not the OEM laser plug and I doubt it will last anywhere near as long as the OEM plug.
I had my OEM plugs in for 12.5 years and 108,000 kilometres (67,500 miles) and probably could have got more life out of them than I did as my car was running perfectly and the fuel economy hadn't suffered.
I highly doubt it.
And yes thats what it is ive been using the Laser's thank you for te reminder.[/QUOTE]
Old Mar 4, 2011 | 02:30 PM
asand1's Avatar
No, "all this" was in response to the OP
Hey ya'll,
Dont flatter yourself FallenOne
Old Mar 4, 2011 | 04:12 PM
Product_Of_Korea's Avatar
Coppers FTMFW
Old Mar 6, 2011 | 05:01 AM
pewteralti718's Avatar
spark plugs: oem or any ngk, just no bosch
air filter: oem or k&n drop in
fuel filter:300zx
new oem pcv valve
clean iacv
Old Mar 6, 2011 | 12:04 PM
A big THANKS to all who helped!
Peace
Old Mar 6, 2011 | 03:05 PM
Bobo's Avatar
I have posted a response earlier on with some suggestions. Apart from that, I believe there is a sticky describing what is typically done at 60,000 miles. You should take a look at it. A Haynes manual is also worth the investment and doesn't cost that much.
Peace
Old Mar 6, 2011 | 06:27 PM
FallenOne's Avatar
Or the FSM thats in my Sig!
Old Mar 10, 2011 | 01:59 PM
HubZap's Avatar
A32 Tune Up
fuel filter:300zx
new oem pcv valve
clean iacv
Thanks for this info. Is there anything else that is required for a basic tune-up? Or could you at least point me in the right direction of the postings I should be looking for? I recently registered to fix up my sister's 1999 Max SE w/187k miles, I've worked w/cars before but never with Nissans, I understand they are particular re: when to use OEM and aftermarket parts.
Thanks again all...this is my first posting, 14 more to go!
Old Mar 10, 2011 | 03:38 PM
Bobo's Avatar
Research the stickies. The 60,000 mile tuneup particulars are there. Basically there is no tuneup as such like in the old days when timing needed to be set and distributor caps, points and rotors required replacement.
Spark plugs, fuel filter and PCV valve are about it. The rest is fluids as required: oil, coolant, transmission, power steering. Then there are inspections of exhaust, steering, CV boots, belts, hoses, turn signals, backup lights, brake lights etc.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gavin68
Sep 18, 2021 12:36 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
