00vi VIAS Control Solenoid Valve Current
Does anyone know how much current the VIAS Solenoid take?
I know that the voltage is 12V, but I'm also interested in the current.
I have a RPM switch that in the specs says that it can't take any more then 3Amps - don't really want to blow a switch by drawing too much current across it.
Also, the 2001 FSM has no information on the current.
14 Volts/14 Ohms = 1 Amp.
I suspect that the current requirements of the solenoid are well below what the rpm switch is capable of supplying. Especially considering Nissan uses the ECM directly to control the VIAS solenoid, and does not use a relay as they would if the solenoid was high power.
You should have no problem activating the solenoid with that RPM switch.
Max139617
Sep 20, 2015 07:09 PM
03VQMAX
Sep 5, 2015 03:47 PM
