wont turn over and start. help, tonight! does run though. alternator? starter?
so ever since i got my max in april, it has taken its time starting. likt instead of starting right up, you have to hold the key. its been getting worse in the past week. sometimes it will stop turning over (i always thought it was my foot slipping off the clutch and the button not being pressed in)
today is the first day it had the major problem of not turning over. it DOESNT make the clicking sound like when you have a bad starter (i know, ive owned a 95 and had the starter go out). it acts as if the battery is dead.
which i know isnt. so today i have pushed the car and popped the clutch to start it. and it runs fine and everything. it just wont turn over. and today ive been running it with the radio off so it would have less to power.
last night i noticed when i had the car running, i would press multiple window switch buttons and my headlights would dim. also, ever since may ive had 2 10" subs wired to the stock bose amp. (i found a way to get it to work with 2ohm vs. 4ohm). it also has a new duralast battery, so i know its not anything to do with that.
so my theory is either the alternator has been "killed" because of the power im requesting from it. or, i need to rebuild/replace my starter.
i know what i wrote is long, but i would like some help tonight so i can have my car for work tomorrow
I would start with the alternator. Can you get it to start back up? You need to check the difference in voltage when off and when running. If that checks out, then I would check the starter.
i know its not good to do, but the starter dones crank over when the car is running. obviously because it doesnt need all the torque to start the engine.
so id say starter. ill check it out tomorrow morning when i have the time and patience.
i have a similar situation, do you have a check engine light? it might help to put a ground kit on it or even an extra ground wire from the - side of the battery to the engine side bell housing, our 4th gens are notorious for starting like hell if the ground is weak.
you might also want to clean your crankshaft position sensor( if you lift the car its on the bottom side of your crankshaft pulley.. take it off and clean it well and put it back on the car and see if that helps. I know that i need that sensor so mine is a biotch to start but if i put the car in neutral, it helps and if that doesnt work try rolling the car forward or backwards about 6 inches. lemme know what happens and if that resolves the issue. if you have anymore suggestions pm me your number and ill text you when i get a chance
no check engine light. and id really hate to remove the main pulley if i dont have a replacement one. ive had to remove it and replace it on my 95. talk about a pain in the ****. and its easier if the car will crank over. thats how i got the bolt loose. put a breaker bar and socket on it and cranked the motor over. not the best way, but it worked.
no to remove the crankshaft position sensor you dont have to remove anything but the sensor itself jack the car up slide up under th car and youll see the sensor right on the bottom side of where the crankshaft pulley is at. IIRC its just 2 bolts and unplugging the sensor it may be just the one bolt i cant remember to be honest
just waiting on a ride to get ti tested at oreillys
i would seriously add a ground wire from the engine side of the bell housing to the negetive side on the battery.. make sure to take a wire brush to both wire ends and wherever you put them
okay.
so i have 2 options.
1. buy a starter from oreillys for $120 with lifetime warranty
or 2. wait til tomorrow and go to pick n pull and get one for $30 and hope it works. with 30 day warranty
check your grounds. I had the same symptoms (dimming lights when using accessories etc). Turns out battery terminals were corroded and grounds were not good. I would clean everything up first before you start replacing parts. It's worth a shot! Good luck.
yup, bad starter. tested and failed. so ill be hitting up the junk yard tomorrow. saves me $100
yes, i definately will look into a grounding kit. i know a member here sells them. but im sure i could make my own
but anyways, i did get it fixed. went up to pick-n-pull and got one. cut my hand open because the cheap socket i used cracked and slipped trying on one of the cars up there.
but i forgot to plug in my maf sensor before connecting the battery so now i have a cel. gonna go to the garage and have them clear it for me.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
doobadoo
Aug 15, 2015 06:43 PM
