Swapping 99 Maxima seats into an I30 - SRS question
Old Jul 17, 2011 | 06:21 AM
CS_AR's Avatar
Is it possible to swap the leather seats on a 99 Maxima (without SRS) into a 99 i30 that originally came with seat SRS?
I have an i30 with SRS seats that need to be replaced and some good condition 99 Maxima seats without seat SRS. I would like to replace the I30 SRS seats with the non-SRS Maxima seats.
A couple of weeks ago, the ECM from the non-SRS 99 Maxima replaced the I30's bad ECM. Dealer reset NATS. No problems so far.
Will moving the SRS module (under center console) from the 99 non-SRS Maxima into the i30 and then resetting codes resolve the SRS light?
Old Jul 17, 2011 | 09:33 PM
pmohr's Avatar
No more Maximas...
From a quick look through both FSMs, the pinouts should be the same and I imagine that a '99 airbag module w/o side airbags should indeed fit in a '99 i30, and resolve the SRS light from not using seats with side airbags.
Never having done this, I can't say for certain, but I would say yes, it should work.
Old Jul 18, 2011 | 10:02 AM
danmack34's Avatar
I wouldnt do it I would find some seats with the srs
Old Jul 18, 2011 | 01:23 PM
DennisMik's Avatar
He would have to swap the air bag sensor module under the console. It is a different module with side air bags than without them.
Without side airbags, the module has only one wire harness connector, whereas with side air bags the module has 2 wire harness connectors. The 2nd connector is for the satellite sensors that go with the side air bags.
Old Jul 18, 2011 | 01:51 PM
pmohr's Avatar
No more Maximas...
Isn't that exactly what he asked in the first post?
Old Jul 19, 2011 | 07:15 AM
njmaxseltd's Avatar
One time, when I was in band camp....
Old Jul 20, 2011 | 09:26 AM
oldngivout's Avatar
Willing to learn
This is correct.
I did this on my 98 I30. Swapped in non-airbag seats AND the correct airbag module under the console. You will have an unused electrical connector in the harness. Other than that, no problem.
Finkle
Sep 27, 2015 09:53 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
Blackwind
Aug 5, 2015 06:35 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
