Door open light on.
Old Jul 21, 2011 | 08:39 AM
skypilots's Avatar
Door open light on.
The door light open light goes on and off. I cant lock doors because alarm will go off at some point. Anyone have any of these problems? What did you do to correct it.
Old Jul 21, 2011 | 09:55 AM
DennisMik's Avatar
Maybe you are having problems with one of the door switches. When the door is closed, stand outside and try pressing on the door where the switch is and releasing it and see what happens. Since the driver's door gets most of the usage, start with that one.
Old Jul 21, 2011 | 10:32 AM
skypilots's Avatar
I push the door switch in by hand on all doors and the light still stays on. Is there a way i can kill the door lite and not affect my alarm?
Old Aug 23, 2011 | 04:48 PM
irish52084's Avatar
Check the contact points for corrosion. I've seen that cause this issue on other cars several times. Bad continuity so it thinks light should stay on, just clean the connection if necessary.
Old Aug 23, 2011 | 08:17 PM
DennisMik's Avatar
Our door switches are an open circuit when the door is closed. When you open the door, the connection is made to ground. So if there was corrosion on some connection, it would be as if the door wasn't opened.
Old Aug 23, 2011 | 10:55 PM
nismocarrion's Avatar
I had the same problem turned out to be my hood switch very weird.
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Flores94
Aug 11, 2015 12:53 PM
Blackwind
Aug 5, 2015 06:35 PM
