Anyone know what this is??
Old Jul 22, 2011 | 04:59 PM
MAXIMA_STYLE's Avatar
Anyone know what sensor this is? i was just recently lookin at my engine for an attack plan on changing my knock sensor and noticed this has nothing plugged into it and seems as if there is a vacumm line disconnected nearby also...any ideas?
Old Jul 22, 2011 | 06:11 PM
max ride 41's Avatar
look for a loose hose and plug and plug it up!! you'll find out when the extra powa kicks in or a cell kicks on...
Old Jul 22, 2011 | 06:21 PM
Thats the problem bro, i cant see any "extra" plug anywhere near it, i have an emply plug next to my drivers headlight but its only 3 inches long something else i just found also....and the vac hose....no hose anywhere else....
Old Jul 22, 2011 | 06:29 PM
T-Mon3y's Avatar
looks like its got a part number on it. but i can't read it. try to get a better shot of the numbers.
Old Jul 22, 2011 | 06:49 PM
i blew it up and the numbers are from the top--- k5146583 next row--- 7z09. dont know what the thing is next to the 7 in bottom row.
Old Jul 22, 2011 | 07:01 PM
i did blow it up, i ran the numbers that i seen on it, searching came back with NOTHING
Old Jul 22, 2011 | 07:05 PM
its obviously an option that your max did'nt have or need. i would'nt worry about it. i know its eggin you tho....
Old Jul 22, 2011 | 07:07 PM
neocry's Avatar
It looks like MAP sensor solenoid switch.
Old Jul 22, 2011 | 07:08 PM
Crusher103's Avatar
It looks like the auxiliary power unit for the rear ejection seat.
Old Jul 22, 2011 | 07:11 PM
as map sensor switch?? when i bought the car the girl gave me a print out from autozone...said either map sensor or maf sensor.....hmmm
Old Jul 22, 2011 | 07:17 PM
neocry's Avatar
Or it might be this valve solenoid.
http://www.courtesyparts.com/14956va...-p-130362.html
Old Jul 22, 2011 | 07:25 PM
neocry's Avatar
And she is right because, the MAP sensor is located right on your factory air intake snorkel and the MAF sensor is located near the left fender which is 4 times the size of what you've posted.
it could be, id have to look at it again to verify the tubing on it, if that is the case WTF is it for??
Old Jul 22, 2011 | 08:05 PM
T-Mon3y's Avatar
MAP = Manifold Absolute Pressure sensor
Tells the ecu how much air pressure is in the intake manifold to determine how much load the engine is under(helps ecu determine A/F ratio combined with readings from other sensors, MAF, TPS, etc...).
Old Jul 22, 2011 | 09:06 PM
Maxima_Joe's Avatar
4th Gen Parts King
That would be the MAP/BARO switch solenoid valve.
Old Jul 23, 2011 | 07:08 AM
I see... well i guess its time to search for a vacumm diagram from it to where it belonds and also where would the connector be.....
Old Jul 23, 2011 | 07:32 AM
MOHFpro90's Avatar
Just get any sort of vacuum line and tap it into any vacuum source. Doesnt matter where, just needs vacuum. The plug should be somewhere; if i remember, the pcm only uses the MAP as a reference/backup.
Old Jul 23, 2011 | 07:40 AM
i dont see any connector....matter of fact i dont even see a map sensor on my car..... i know what the maf is i see that the intake snorkel was somewhat disconnected underneath...reconnected that, but i dont see no map sensor, and when i run a search for a 95 map sensor it comes back as 96-99....did they not use them in a 95?? or is google search just retarded? the only plugs i see is one directly on the side of the battery try, a 2 pin plug and then theres one near my front drivers corner assembly which has 3 pin connections...wtf are those lol...seems as if someone did something to this car they shouldnt have...
Old Jul 24, 2011 | 08:46 AM
RA030726's Avatar
I'm nutty for Nissans
What year is your car?
Full engine bay pic please.
