worn ignition switch
Old Jul 24, 2011 | 01:23 PM
metal_god98SE's Avatar
After starting the car, sometimes the switch wont go on its own to the position where it engages the circuit with the radio, wipers, and clock.
What is the method to replace the switch? Is it safe to assume that it must be ordered through Nissan?
Thanks in advance.
Old Jul 24, 2011 | 03:10 PM
DennisMik's Avatar
It isn't that difficult overall. You remove the plastic covers that are around the steering column, the plastic panel that is across the bottom of the dash and the metal plate that goes across the bottom of the steering column. Then the ignition switch comes off with 2 phillips head screws. It's advisable to disconnect the battery as there are un-insulated contacts on the ignition switch.
I think that you can only get the switch at nissan, around $40.
Old Jul 24, 2011 | 03:18 PM
martyscholes's Avatar
Search the forums
I replaced mine a few months ago in an hour or two. Switch was from autozone for some $35.
Most of my time was spent being cautious, e.g. "Did I remove all of the screws and this piece is only being held by a clip, or will I rip something if I pull harder on it?"
The next time I do one it will take less than 20 minutes.
It's very easy.
Old Jul 28, 2011 | 12:55 PM
cashoit's Avatar
SEARCH man.
Phmor has a youtube video for install. Its really really really easy to install.
Old Jul 29, 2011 | 03:14 AM
infinimax96's Avatar
Originally Posted by cashoit
SEARCH man.
Yep using his exact video I installed a new switch in my i30 tonight while in a 7eleven parking lot. The switch finally took a turd on me so I ran to Autozone to pick one up. $34.09 with tax. looked his video up on my youtube app. Drove back to 7eve and slapped it in. only took a standard Philips screw driver.
Old Jul 29, 2011 | 06:38 AM
jas1203's Avatar
If you're willing to spend the extra $10-$15, I'd get an OEM switch. It might just be me, but I've had horrible luck with aftermarket switches...from some which hate heat, to others which get "sticky" like yours. Put in an OEM one and it's outlived all of the aftermarkets I've tried combined.
Old Jul 30, 2011 | 01:58 AM
I bought the Duralast one from Autozone. So far haven't had any problems. Car even sat all day in the sun, still fired right up. I'll update if I have issues with it in the future.
Old Jul 30, 2011 | 07:51 AM
jas1203's Avatar
Hope it works out for you...I think the heat thing was the strangest issue any of mine had. Might just be bad luck for me .
Old Jul 30, 2011 | 05:55 PM
96MaXiclean's Avatar
Just replaced mine in March, piece of cake...
Got it off ebay, no issues, plug and play, fires right up...
Here's the video I used...
http://youtu.be/4ykT9uCJXSY
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
