wire manual
Old Dec 28, 2001 | 12:58 PM
maxi-milliyon's Avatar
wire manual
Where the heck can I get a wire manual for a 97 Max. When I bought the car many wire were cut. My cruise control light on the dash blinks
but doesn't work. also I heat control unit doesn't light up either.
If I had the wire manual I could trace each wire. Also How do you hook up the headed seats that are not pre wired. I have a harness for the heated seats but I don't know if the line is cut.
Maxi
Old Dec 28, 2001 | 01:43 PM
SuDZ's Avatar
Re: wire manual
Where can I get technical information on all the parts of my Maxima?
BEFORE ATTEMPTING REPAIR/REPLACEMENT OF ANY MODIFICATION OR MAINTENANCE ITEM, IT IS HIGHLY RECOMMENDED YOU PURCHASE ONE OR ALL OF THE FOLLOWING:
- Nissan Maxima Factory Service Manual
Where can I get the FSM?
You can order this direct from Dyment Distribution Services. This is where your local dealer orders it also( for the same price as if you order it, so it is usually cheaper and faster to simply order it yourself.) They have manuals for almost all Maximas. They also have original owner's manuals available.
20770 Westwood Road
Strongsville, OH 44136
How much is the FSM?
Special thanks to member "SuDZ" for obtaining all pricing information
3rd Generation Maximas:
All years, 89 to 94: $73
4th Generation Maximas:
1995: $93
1996: $107
1997 & 1998: $119
1999: $125
Contact Number for 3rd and 4th Gen Maximas: (800) 247-5321
Fifth Generation Maximas:
Fifth Generations are a little bit different. They are available in both printed and CD Rom format.
Printed:
2000 to 2001 - $275
CD-Rom:
2000 to 2001 - $210
Also if you call in for a 2000 you will be asked for your VIN# so please have it on hand. There are two editions avaiable and they are based on your VIN number. This is not the case with the 2001 model.
Contact Number for 5th generation Maximas: (800) 639-8841
That's too expensive. Can I find used ones anywhere?
This fellow deals in used factory service manuals:
http://www.swapmeet2000.com/
This is another good source of used factory service manuals:
****son Street Bookshop
325 West ****son
Fayetteville, AR 72701
dsbooks@ipa.net
I bought one from ****son and recommend them.
The book was fairly priced, in good condition, and shipped promptly.
This a good on-line catalog site:
http://www.factoryautomanuals.com/
Keep an eye on the eBay auction site. They often have factory service manuals for sale:
http://listings.ebaymotors.com/aw/l...6029/index.html
In the search field, enter: maxima manual
- Aftermarket Service Manuals
What are the aftermarket manuals and where can I get those?
Chilton's Nissan Maxima 1985-92 Repair Manual, ISBN #0801982618
Haynes Repair Manual, Nissan Maxima, 1985 - 1992, ISBN #1563923653
Chilton's Nissan Maxima 1993-98 Repair Manual, ISBN #0801989612
Haynes Repair Manual, Nissan Maxima, 1993 - 1999, ISBN #1563923599
These are available online at Barnes and Noble, buy.com, amazon.com, etc.
An example link to Barnes and Noble:
http://shop.barnesandnoble.com/book....asp?WRD=maxima
What are the differences in the Factory Service manual as opposed to the aftermarket service manuals?
http://vbxmaxima.8m.com/manualcompare.html
Other thoughts courtesy of Daniel B. Martin
It is worth $15 for an aftermarket manual even if you have no intention of working on your own car. The manual will teach you the correct names for car parts. That helps you write clear questions in forum posts. It is better to say "clutch slave cylinder pushrod" than "that little black **** thing that moves".
These manuals will help you differentiate between small jobs and big ones. This will make you an informed consumer, able to avoid overcharges by service facilities. In plain language, knowledge will prevent you from being a rip-off victim.
Don't overlook the Owner's Manual. It has maintenance schedules, fuel/lubricant recommendations, capacity specifications, and a good chapter titled Do-it-yourself.
Where can I order another owner's manual? Can I view it online?
Special thanks to member "Ravq" for this link
In addition, here is a link for all 1995 to present Maxima owner's manuals in Adobe Acrobat PDF format:
http://www.nissan-techinfo.com/deptog.asp?dept%5Fid=37
Old Dec 28, 2001 | 01:44 PM
SuDZ's Avatar
Most of the manuals above are going to give you a wiring diagram of your car. The nmost in depth (but most expensive) will be the factory ones. It is up to you.
SuDZ
Old Dec 29, 2001 | 01:14 PM
manual
Thanks for all the info!
Maxi
my03maxima
Jul 28, 2024 07:40 AM
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Oct 28, 2019 10:58 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
