CEL after valve cover gasket changes
Old Sep 2, 2011 | 10:10 PM
Perseus's Avatar
after changing both valve cover gaskets i got these two codes
Idle Speed Control 0205
MAP/BARO SW Solenoid/Valve 1302
since it's a three day weekend i thought now would be the best time to address the issues, or at least learn more about them. from what i've read the first has to do with the IACV and the second is a part that's on the passenger side of the intake manifold. did a bit of searching but i can't find anyone that posted these codes after a gasket change (though it does make sense since both of these areas were touched)
anyways, if anyone has info on these codes or what i should to do isolate the issue, please post them! the CEL bugs me every time i drive
Old Sep 2, 2011 | 10:13 PM
asand1's Avatar
Check you hoses and connectors. Something you disconnected didn't get reconnected right.
Old Sep 2, 2011 | 10:24 PM
Perseus's Avatar
is there a reference pic somewhere? that's one of the issues that i could think of, but everything appears to be where it should be
Old Sep 2, 2011 | 10:45 PM
BenL's Avatar
+1 I'd check for one (or more) of the smallest hoses being disconnected (make sure to look behind and under things). The one nearest the TPS is especially easy to miss if you're not looking for it... I should know .
Also make sure the one on the bottom of the throttle body is hooked up, easy to miss if you're going over the vac system with the full intake in place.
Old Sep 3, 2011 | 12:35 AM
SandyMax96's Avatar
I would check specifically those two hoses, since they're out of view when everything is in place. And if you're getting a MAP/BARO code... check the solenoid by disconnecting it from the harness and checking the ohms using a tester. Most of the time, it will be bad, and could just have given up after doing the gasket replacement. But... if you didn't touch anywhere near that area, you shouldn't really have had a problem in the first place but, check the ohms... (the term for it is currently blanking out in my mind, but I'll re-edit when I get the chance in the morning) and if it's good, just make sure that you did NOT switch the hoses from how they're configurated!
Old Sep 3, 2011 | 06:48 AM
jholley's Avatar
Within this 4th GEN forum do seperate searches of 'IACV picture' and then 'MAP picture'.
jmlee44
Oct 2, 2022 02:13 PM
jonreidhead
Jan 6, 2016 09:38 AM
knight_yyz
Nov 1, 2015 01:34 PM
tseng1023
Oct 15, 2015 08:30 AM
