what are you currently waiting on?
YO. YOU ALL NEED TO CHECK OUT THESE FLOORMATS PRETTY MUCH. THEY ARE BALLIN.
front left
rear left
front right
rear right
solid aluminum diamond plate. powedercoated black. the nismo emblem is cut out of the diamond plate. theres separate metal behind the cut which is painted white or red.
I ALSO DID THIS
the other day
95maxed: do you see the difference between my corner lights and bumper lights and yours? yours are flat and rough. (despite the fact that i need to rub my gasket on my corner lights with lacquer due to not maskin them off lol
front left
rear left
front right
rear right
I ALSO DID THIS
the other day
).I don't see how that's something your waiting on if their already on the car.
Way to follow the OPs request.
My shocks aren't shot but the ride is very harsh on sh1tty NJ roads so.... I've bought monroe sensa tracs, tein h-tech springs will be delivered on wednesday, bought a driver side raxle, will buy new dorman brand control arms ($90 shipped from rockauto) before i finally take all the **** to my mech...
Are you going to use the 5th gen IACV or remove block off and use the 4th gen? I suggest the later for less of a hassle
No they are different and its a hit or miss with the 5th gen IACV, some had no problems and some couldn't get it to work for the life of them. So try it and if you have problems just remove it and block it off and use the 4th gen one and save yourself the headache. Check this out http://tatanko.boredmder.com/ go under "00VI SWAP"on the left then click on "Setup comparisons" in the center. I was going with setup #2 when I had my 4th gen, basically all 5th gen stuff except for the IACV.
There's also tons of useful info about the swap in there, I suggest you look through it and study it carefully so you don't run into problems later.
hey simon, how are you man??? is the surgery from the accident you had last summer?? so im guessing your driving again??? soon??? ( should've got the yoko invigors man, much better handling imo. )
Waiting on stage 2 clutch kit, cold air intake kit, short throw shift kit, and waiting on this weekend to install the 600 dollar 5 speed swap in my 97.... So technically im waiting on those parts to be put in hahaha.
I've been waiting for my fuel gauge sending unit that mounts in the gas tank. The one in the car has a cracked mounting plate and allows gas to leak out, which really smells in the car. So I get home yesterday to find a crushed box by my door.
Good ole UPS. So today my project is to find out how to get a replacement. In the past, this has been a 3 to 4 month process.
update 11/18/2011
So the parts place told me to open the box and I did. As best I coul tell, the sending unit looked ok. Electrically it tested OK as per the FSM so I went ahead and installed it. Time will tell.
my thread with pictures:
http://forums.maxima.org/4th-generat...ding-unit.html
Good ole UPS. So today my project is to find out how to get a replacement. In the past, this has been a 3 to 4 month process.update 11/18/2011
LOL
