Maxima gauges HELP!!
Old Sep 18, 2011 | 05:18 PM
xWTFxREALLYx's Avatar
Alright so I bought these reverse glow gauges from paradox-systems.com. As you can see I don't know why the freaking needle gets stuck on 30 when idle and doesn't go down from there(ever). After I pass 30 the needle starts moving and I really need help with this from someone that knows what there doing please!!! Also I choose from the desired options on the gauges but it always goes back to the first one which I don't want because I want the one on the picture, so that when I turn on the lights that one comes on and not the first one.
Please I would really much appreciate anybodies help and thank you
The site where I bought these are:
http://www.paradox-systems.com/produ...products_id=74
This is while the car is off and just the lights are on.
Old Sep 18, 2011 | 05:31 PM
tigersharkdude's Avatar
Not sure. Did you pull your needles off to put the overlay on? If so, you may be screwed
(buy my white face SE cluster for $50)
Old Sep 18, 2011 | 05:45 PM
No the needles werent pulled off
Old Sep 18, 2011 | 06:07 PM
MOHFpro90's Avatar
How were the needles not pulled off?
Old Sep 18, 2011 | 06:36 PM
BORQUA79's Avatar
nycmaximas member
Did you check the obvious, like if the face is high around the 30mph area or if the needle was bent?
Old Sep 18, 2011 | 08:02 PM
well they pop off but the whole thing does like usual.
What do you mean? and no the needle isn't bent
Old Sep 18, 2011 | 08:09 PM
maxprivate's Avatar
Black Lion
I have read about problems like your having when installing those indiglos. Make sure that the gauges are not bubbling up slightly at any area around the surface of the gauge. That will cause the needle to not move. So around the 30 mph area the gauge is not flush thus causing sticking in that area.
Old Sep 18, 2011 | 10:09 PM
Yeah its that but do you know how to fix it?
Old Sep 18, 2011 | 10:12 PM
cartman854's Avatar
Hair blow dryer.
Razor blade.
Pop the bubble??
Old Sep 18, 2011 | 10:15 PM
Originally Posted by cartman854
Hair blow dryer.
Razor blade.
Pop the bubble??
really -_-
Old Sep 18, 2011 | 10:18 PM
cartman854's Avatar
Originally Posted by xWTFxREALLYx
really -_-
What is causing it to stick exactly?
That could help.
Old Sep 18, 2011 | 10:44 PM
That could help.
Alright so this is the deal the needle never goes down under 30 and when im going faster it moves but when im on the freeway it skips into the right speed so the needle like jumps forward to like 60 or so depending on the speed im going, so this is what im trying to figure out.
Old Sep 19, 2011 | 04:06 AM
maxprivate's Avatar
Black Lion
Double sided tape. Make sure its a thin layer. Make sure the needle moves freely before and after the install. This will be trial and error.
Old Sep 19, 2011 | 06:35 AM
BORQUA79's Avatar
nycmaximas member
I wouldnt have said it better!! I recently removed mine. I used the double sided tape and definitely double check that the needle moves freely. Make sure you take note of where the fuel needle is set at. Because if you move that one by mistake you won't have an accurate fuel reading.
Old Sep 19, 2011 | 06:54 AM
aackshun's Avatar
+1
Eh? It resets itself, well my 99 SE-L cluster did anyways.
Old Sep 19, 2011 | 07:01 AM
BORQUA79's Avatar
nycmaximas member
Originally Posted by aackshun
+1
Oh? I wouldn't know because I made sure it was back to were it was. But I honestly I could have gotten the wrong info. Thanks for clarifying and correcting.
Old Sep 19, 2011 | 09:16 AM
My brother said that was all i needed but he just wanted to make sure that double sided tape could fix it so thanks guys yall were a good help ^_^
Goffery2uned
Aug 21, 2015 09:50 PM
acw
Aug 13, 2015 12:50 AM
julian888
Aug 6, 2015 04:39 AM
