BAD TPS?? IS IT ADJUSTABLE?
Old Sep 19, 2011 | 02:15 PM
da God's Avatar
Since I had 4th Gen Max in '05 it shifted hard into the 2nd gear when at regular throttle. I have an automatic. If I start throttling hard from 0mph tho theres much less of a hard shift. And by hard shift I mean it feels like the engine is bucking, like the cars gettin hit by something. Sometimes i even try and let off the throttle as Im approaching the height of the gear to ease the bump. No other gear has a hard shift. Only the shift into 2nd gear.
I compared a friend('99 Max) and my TPSs, they are at different heights (1/2" difference) on the throttle body. It appears to be adjustable. So Im wondering CAN THis thing be adjusted?? Can I Lower it a bit or something and try and see if it fixes the problem?
I did take out 1 of the 2 plugs that goes into it and saw no change in performance. When i took out the other the car became practically un drive able.
reference TPS threads below couldnt answer my question.
http://forums.maxima.org/4th-generat...5-bad-tps.html
https://maxima.org/forums/3rd-genera...-gone-bad.html
http://answers.yahoo.com/question/in...8172330AACsdGh
Old Sep 20, 2011 | 11:44 AM
da God's Avatar
Damn 58 views and no comment??? No one has any info on this?? I have the FSM and it doesnt say anything about the FSM being adjustable. I figured if its bad it just needs a replacement. But I dont know if the Throttle Position Sensor is the Cause of the problem yet.
Old Sep 20, 2011 | 12:38 PM
DBear's Avatar
Yes, it's adjustable. You just loosen the screws and rotate it to match the specs in the FSM EC-133. And here's the new improved method: http://www.lyberty.com/car/Maxima_A3...NTB99-053b.pdf.
But offhand, I'd say it's more likely to be your drop resistor.
Old Sep 20, 2011 | 06:38 PM
da God's Avatar
Alright guys Im putting this into a new thread linked below. please no one needs to comment in this one.
http://forums.maxima.org/4th-generat...ml#post8209972
Old Sep 20, 2011 | 06:44 PM
da God's Avatar
thanks Im replying in the new thread cause the title is misleading. Im lookin into the drop resister now
http://forums.maxima.org/4th-generat...ml#post8209981
tarun900
19
Dec 20, 2021 06:57 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
