ac wont blow through vents. stuck on defrost.
Old Oct 21, 2011 | 12:41 AM
TravisCadello's Avatar
yesterday was our first cold day here in Houston Tx and go figure my vents wont blow through the vents only on defrost what could be wrong?
its a 99 with digital gauges.
no matter if on ac or heater.
Old Oct 21, 2011 | 08:50 AM
cashoit's Avatar
Either the door is stuck, the actuator for the door isnt working, or the Climate control unit is busted.
Old Oct 21, 2011 | 09:53 AM
DennisMik's Avatar
There is a self diagnosis in the FSM. It starts on page HA-70 in the 1999 FSM. It has 5 sections that run in a row. Section 3 tests the duct doors. IIRC, one of the section takes a bit of time, so don't worry. Hopefully this will help.
If you need a FSM, download it here -
http://boredmder.com/FSMs/Nissan/Maxima/
Old Oct 22, 2011 | 04:59 AM
seems like a bad relay because i used to here a clicking noise when i pressure the button to change air position now no clicking.
Old Oct 22, 2011 | 06:26 AM
i can find a way to make the door stay open, can i somehow do that to get it stuck on vents?
Old Oct 22, 2011 | 12:46 PM
max ride 41's Avatar
travis, i've come to the conclusion that your max is haunted!!!! i've seen a bunch of threads from you and am so glad i never bought a 99. maybe thats why they changed a bunch of things in 2000????
Old Oct 22, 2011 | 01:14 PM
LOL all the problems hit me at once lol. its like damn slow down im poor lol.
Old Oct 22, 2011 | 01:31 PM
DennisMik's Avatar
The doors inside the air ducts are controlled by electric motors that are powered directly by the climate control push buttons. There are 3 motors in total. The one that's not working for you is the "mode door motor". It could be the motor is bad or it could be that the control panel is bad.
What did the self diagnostics show you?
Old Oct 22, 2011 | 02:48 PM
couldnt even figure out how to use ur link lol.
Old Oct 22, 2011 | 06:59 PM
DennisMik's Avatar
After you click on the link, you get a list of the different years that you can download a FSM. You click on 1999 (I believe that's what you have) and then you get a list of the different sections (or chapters) of the FSM. These are in the Adobe PDF format.
You can download all the files and save them on your hard drive or you can download only what you want. The file named fwd.pdf is the cover page or the index of the FSM and is the starting point to using the manusl. The file named IDX.pdf is the alphabetical cross reference.
For right now, all you need is the HA file, meaning Heating and Air Condition. After the file displays on your screen, you would click on the save button (3rd from the left) that looks like a floppy diskette.
Old Oct 25, 2011 | 08:23 PM
noone has made a sticky on how to change the internal gears for the flapper? i dont wanna start something and not finish it.
Old Oct 25, 2011 | 08:42 PM
where is the air mix connector located at?
Old Oct 27, 2011 | 12:44 AM
so the motor should be in the center console behind the radio somewhere? how do i know what it looks like?
Old Oct 28, 2011 | 04:20 AM
DennisMik's Avatar
you are going to have to look up under the dash from the driver's side footwell. Look at the white plastic box "thing" that is the air duct distribution box that sits above the ECU. You will see the motor attached to the side of this. It is a black, square thing that is about 3 inches across.
Old Jan 13, 2012 | 02:19 PM
cant i make it temporary blow threw vents some how?
Old Jan 13, 2012 | 03:34 PM
talk about slow reaction time.....uppet:
Old Jan 14, 2012 | 10:53 AM
DennisMik's Avatar
You can take the motor off and the flapper door inside should move freely. Your problem will be to get it to stay in the position you set it in.
Old Apr 21, 2012 | 12:05 AM
Lol ya i gave up on it for a while i got under dash n couldnt get it to move i want it stuck on vents think ill have to take her to stealership to fix it cause noone can fix it i called plenty shops.
Old Apr 21, 2012 | 12:10 AM
Thats the problem i cant even find the motor no idea where its at.
Old Apr 21, 2012 | 12:28 AM
2brosgixxer's Avatar
The Blower motor?? Pull the glovebox out, look back there and it will look something like this (in the link below)...in this pic, the blower motor has already been removed but it goes where that big hole is. Don't know if thats what you are looking for though
http://home.earthlink.net/~pje112590...orlocation.jpg
EDIT: Heres what it will look like with the blower motor still in, just remove the entire glovebox to see this http://media.photobucket.com/image/9...a/IMG_0127.jpg
Old Apr 22, 2012 | 03:57 PM
DennisMik's Avatar
Originally Posted by 2brosgixxer
The Blower motor??
No, you somehow mis-read the thread.
Old Apr 22, 2012 | 04:13 PM
Yeah, I didn't really read the whole thing thoroughly...saw motor and just assumed blower motor...my bad
Old May 16, 2012 | 12:29 PM
Yah ok i messed with it i get it from defrost to blow on feet but not out vents and the thing like as soon as i let go of it goes right back to where it was positioned at before.
Old May 16, 2012 | 09:06 PM
DennisMik's Avatar
Now that you found the motor, turn the ignition switch on at look at it while you are pushing the different buttons on the control panel. The arm on the motor should move. If it doesn't, we are back to the earlier statement that either the motor or the control panel is bad.
Old Nov 10, 2017 | 10:31 AM
nissan99's Avatar
Well I’m in the same boat same thing it works on defrost and not blowing Thur the vents so changing the motor is that hard ?
Old Nov 10, 2017 | 11:05 AM
DennisMik's Avatar
The motor is out in the open, so it is moderately easy. Just carefully observe the linkage and positions.
Old Nov 10, 2017 | 11:23 AM
nissan99's Avatar
Thanks Dennis so is this part expensive? Or there after market parts ?
Old Nov 10, 2017 | 11:50 AM
nissan99's Avatar
There it is !!
ok I seen were it’s at and look at it while pushing fan controller buttons mine is auto climate control and the arm is not moving at all .. seem to be some grease on bottom part of the arm ..
Old Nov 11, 2017 | 10:17 AM
DennisMik's Avatar
The grease could be seepage from the shaft? I don't know if you should try to interpret that as meaning bad.
I don't know for certain, but I think the motor is a Nissan only part. Nissan calls the motor "Actuator Assy-Mode." There are 2 different motors listed for the car and I think it is because of the control type.
The one listed for the GLE model which only had the auto HVAC controls is part number
27731-40U00 with a list price of $119.80
If you go on-line the part is about $85 but you will also have to pay for shipping. Some places rape you with shipping and service charges. Call your local dealer and ask for a price. Some dealers do discount. There is always the junkyard.
Old Nov 11, 2017 | 12:01 PM
KP11520's Avatar
I have a 99 SE-L and this is the part I used: https://www.ebay.com/itm/NISSANINFIN...tZwhpW&vxp=mtr
Dennis was a BIG help with my same problem. I posted my thread exactly 2 years ago today. I refreshed it and it's right below this thread.
Here's my thread. Some helpful hints on the process in there: https://maxima.org/forums/4th-genera...ml#post9086190
Old Nov 13, 2017 | 12:35 PM
nissan99's Avatar
thanks for the links my 99se so yea that work . I waiting on my blower motor resistor to come in and replace then I will go from there ..
well lk I ran that test I was getting code 31 32 36 so I’m guessing the motor is bad ?
Old Nov 14, 2017 | 05:40 PM
99sagelimited's Avatar
I had the exact same issue on my 99 SEL that I'm trying to get back on the road. The diagnostic routine pointed to the mode door (Codes 31 - 36), so I ordered the mode door motor (or actuator) P/N 27731-2L900 and replaced it tonight. It was very easy. You only need to remove the two screws that hold the actuator to the bracket. All I needed was a short phillips head screwdriver and everything works again. The HVAC has been stuck on defrost for three years now!
Old Nov 15, 2017 | 11:41 AM
nissan99's Avatar
yep I replace the resistor but no luck I figure o well it’s new so it is the motor trying to find a decent price or boneyard time
Old Nov 15, 2017 | 07:26 PM
KP11520's Avatar
Just buy a new OEM one and be done with it for another 19 years.
Only time I'd buy a used one of these is if they weren't available new anymore. It's not stupid expensive either.
Old Nov 15, 2017 | 08:32 PM
nissan99's Avatar
Lol the car won’t last that long ...
Old Nov 15, 2017 | 09:37 PM
KP11520's Avatar
Shhhhhhhh... Don't say that too loud here! People have been burned at the stake for lesser claims.
Old Nov 16, 2017 | 07:26 AM
nissan99's Avatar
Dont get me wrong I love my Maxima great running car ..
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
