check engine light has returned
Old Nov 16, 2011 | 03:39 PM
mayweathers82's Avatar
ok so i knew i had a cel but i had reset the ecu and i felt stupid because i wanted to make sure my car was ok. the light came on while driving to work and i checked it about 5 mins ago
3 4 which is knock sensor, i purchased one because i figured it wouldnt hurt to change it
and 10 5 which is EGRC Solenoid valve. i dont know what that even is. im currently searching thru the forums to find more information on it. what are side effects of this not being replaced? scale of 1-10 on changing it and where should i order or buy the part from . thanks in advance
Old Nov 17, 2011 | 12:33 AM
I would change the KS first, then reset the ECU and see if you've still got the other code.
Old Nov 17, 2011 | 06:42 AM
njmaxseltd's Avatar
It goes the other way around.
Fix the egr issue and see if the ks code comes back.
To the op - search the forums for your error code. There are lots of threads that may help you out.
Old Nov 23, 2011 | 01:55 AM
Zubriski's Avatar
To save money you may want to try bypassing the KS with a resistor (lots of articles on it using search) before spending un-necessary money on EGR stuff
Old Nov 23, 2011 | 06:47 AM
QFT. Often, the KS is a dummy piggyback code. Annoying as hell.
Old Nov 23, 2011 | 06:56 AM
Stephen Max's Avatar
Originally Posted by mayweathers82
... and 10 5 which is EGRC Solenoid valve. i dont know what that even is. im currently searching thru the forums to find more information on it. what are side effects of this not being replaced? scale of 1-10 on changing it and where should i order or buy the part from . thanks in advance
The egr solenoid valve is a solenoid that controls vacuum that operates the egr valve. It is located near the back side of the front cylinder head. It has a vacuum line going to it, and another going to the egr valve. Replace the solenoid first. You may have a bad knock sensor, but your main problem is with the vacuum solenoid.
Old Nov 23, 2011 | 07:28 AM
Br0nz's Avatar
KNOCK SENSOR = $10 RESISTOR MOD = ENGINE DAMAGE
Old Nov 23, 2011 | 07:52 AM
BenL's Avatar
Not if you use premium as is recommended for the car.
Old Nov 23, 2011 | 08:05 AM
Not true. I've never had any problems.
Old Nov 23, 2011 | 04:11 PM
99zx2's Avatar
yup, ours seems to come on every time there is an evap issue.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
