Leaking valve cover
Old Dec 15, 2011 | 04:09 PM
WhiteMaxima9600's Avatar
Leaking valve cover
Wondering if anyone else is having this problem with the front (radiator side) valve cover leaking oil? I removed it and the thick rubber gasket looked great, i cleaned it up and even put some blue RTV sealant on it but it still continues to leak or seep oil. Its mainly on the corner right above the alternator. I just replaced my alt and I don't want oil seeping down into the new one
The bolts are tight and the gasket is fine, why would it continue to leak there I did find the cam position sensor o-ring was hard and letting oil run down from there, i got that fixed with a new o-ring. Has anyone else had issues with this?? Seems like a simple fix but Iam having no luck
Old Dec 15, 2011 | 04:20 PM
tigersharkdude's Avatar
its a common issue. When you pulled the VC did you scrape the old sealant off and put more RTV in its place? The VQ30 is notorious for leaky VC's in the corners. If you re do it use RTV grey and be sure to replace the gasket
Old Dec 15, 2011 | 06:32 PM
maxed_out_99's Avatar
Old Dec 15, 2011 | 06:53 PM
I'll pick up some RTV grey and give it a shot. Yeah i cleaned it up good before but still got the leak, there was only a thick black rubber gasket in it though. Is that the only one it has?
Old Dec 15, 2011 | 07:43 PM
comingup's Avatar
Yes.
Put the cover upside down and put a line of sealant all the way around before you place the gasket in. Push that gasket in good and let it set for about 15-20 minutes then, on the passenger side where the cover goes up then back down, put about a 1.5 inch line of sealant on each side going up and then put the cover on. Make sure you take your time and tighten in sequence.
Also remember the torque specs are in inch lbs, not ft lbs.
Basically hand tight and you should be fine. There really isn't a great deal of pressure right there but don't skimp out on cleaning before application.
Oh yeah, use a new gasket. ~$60 for both sets, including six spark plug grommets. Worth it even if you use just one. Keep the other for backup.
Old Dec 15, 2011 | 07:49 PM
comingup's Avatar
Old Dec 16, 2011 | 11:53 AM
asand1's Avatar
Originally Posted by comingup
Yes.
This is not recomended, and can actually cause leaking due to uneven pressure on the gasket. Just a couple dabs to retain the gasket is ok.
Good advice here, and the ONLY place you should apply RTV. Do get the kit with tube seals and grommets. Your old gasket is still leaking because the gaskets and grommets are compressed just enough, that there is not sufficient pressure applied to the gasket surface.
Old Dec 16, 2011 | 12:38 PM
DBear's Avatar
I have to do the same thing. I have RTV black. Will grey be any better?
Old Dec 16, 2011 | 03:51 PM
comingup's Avatar
they are one and the same
Old Dec 16, 2011 | 08:12 PM
Thanks for the advice guys
Old Dec 17, 2011 | 12:57 AM
comingup's Avatar
I don't understand your uneven pressure claim, I would think it would only help things but I guess we all have our own way of doing things.
Any sources for your claim?
Old Dec 17, 2011 | 02:57 PM
Trini Boom's Avatar
I would say don't skimp out on the cleaning. I never had to use RTV for any of mine. That bolt over the alty the previous owner stripped so I put in a bigger bolt and I clean the surfaces with Throttle Body cleaner and Rubbing alcohol to remove all traces of grease and oil. The gaskets are OEM and I clean those down before even putting them on.
Old Dec 17, 2011 | 03:01 PM
maxfever1987's Avatar
read this as this is very involved and everything is discussed here
http://forums.maxima.org/4th-generat...pair-info.html
Old Dec 19, 2011 | 12:18 PM
DBear's Avatar
Thanks.
Old Dec 19, 2011 | 04:44 PM
asand1's Avatar
Nissan FSM and four years experience.
Old Dec 19, 2011 | 05:02 PM
wirelessdude04's Avatar
Might as well replace both rear and front gaskets. I did mine both at once. i actually added rtv also when i replaced the gaskets.
Old Dec 19, 2011 | 05:09 PM
comingup's Avatar
Well I didn't see any leaks when I changed my knock sensor last night, almost 1,000 miles since I replaced the gasket. I hope it stays that way...
If not, at least I know how to do it now, and probably about a third of the time it took the first time.
Old Dec 19, 2011 | 05:13 PM
asand1's Avatar
From the FSM. I only see four dabs on each VC, above and below the gasket in two spots. X in the black circle indicate "always replace after dis-assembly".
Old Dec 22, 2011 | 05:56 AM
beatermax95's Avatar
I know about the front and rear VC gaskets, are there other places on the engine which have rubber seals that need to be replaced in event of a leak?
Sorry if this is a stupid question, I had both front and rear replaced but can still smell burning oil from the engine bay.
Old Dec 22, 2011 | 09:00 PM
Trini Boom's Avatar
The burning will not stop unless you wash the oil off the exhaust manifold. Also, check to see if oil is running from the oil pan onto the exhaust y-pipe.
Old Dec 22, 2011 | 09:46 PM
max ride 41's Avatar
take a look in haynes or ask any tech, you only put it in corners. your seal will fill the gap and also if it has to come apart its a *****.
Old Dec 22, 2011 | 09:58 PM
2000_MAXIMA_KING's Avatar
Do you guys actually have proof that it would cause problems? I rode 5k miles like that and I just pulled my VCs to take care of something else and they came apart easy (all I had to do was pull them up no struggle) and there wasn't the slightest problem. And as I put them back (tomorrow) I will apply rtv just as comingup said, as it was done before. I only see it helping not harming. Don't see how it causes uneven pressure
Stating something with no actual proof or a simple answer to why makes your statement worthless IMO.
Old Dec 23, 2011 | 05:59 AM
BigLou55's Avatar
I agree, that's why there is a tightening sequence and torque specs. If there existed scientific proof then I'd be on board with the idea of not applying in multiple locations.
Old Dec 23, 2011 | 06:52 AM
because its fact, its not necessary. look at the diagram above straight out of the fsm, nuff said.
Old Dec 23, 2011 | 08:54 AM
BigLou55's Avatar
That just proves that placing it there prevents leaks not adding in other locations will cause leaks. your argument is in the opposite direction as to what is being said big guy.
Old Dec 23, 2011 | 09:16 AM
asand1's Avatar
There are several reasons not to use so much RTV. These are my thoughts, I can not prove them to you.
They just influence the way I do things.
1 Its not necessary.
2 It compresses the gasket further than intended, and accelerates
the eventual leakage.
3 Uneven amounts of RTV can cause uneven pressure on the gasket,
causing spots to be more susceptable to leaking.
4 RTV could break loose inside the VC and plug the oil pump pick up
screen and oil passages.
5 I'm not a hack, I dont use RTV, duct tape, and bailing wire to fix mycar.
I am a former tech, trained and experienced enough to do things properly.
Old Dec 23, 2011 | 09:21 AM
asand1's Avatar
Also, the VC bolts are shouldered, anf the grommets have steel sleeves. This is designed to apply a predetermined amount of pressure on the gasket regardless of torque values. Adding rtv into the VC groove fu<ks with this. See#2 in my list above.
Old Dec 23, 2011 | 01:46 PM
BigLou55's Avatar
asand1, that is excellent reasoning as to why not to use it extra RTV on the VC's. Thanks for reading thoroughly and giving your knowledge.
Old Dec 25, 2011 | 08:55 AM
jholley's Avatar
When I replaced the valve cover gaskets 6 months I applied a small amount of RTV sealant all around the head. I got a valve stuck in bank 1 causing a clicking noise so I had to remove the rear valve cover again. Carefully removing RTV sealant off the entire bank 1 head took more time than removing all the parts. After I dropped oil onto all 12 lifters I only applied RTV sealant in the left corners as the FSM suggest. The valve clicking stopped 20 seconds after starting the engine.
After driving 6,400 miles with these new gaskets I noticed oil was leaking from the front valve cover in front of the dipstick. The front valve cover still had RTV sealant all around the header because I didn't have to remove it to fix any valve clicking. There was no leaking in bank 1 were I only applied RTV sealant in the left corners. Also when I replaced the OEM valve cover gaskets 6 months ago oil never leaked from the front valve cover. It was only leaking from the rear valve cover.
When I replaced the front valve cover gasket 2 weeks ago I only applied RTV sealant on the left corners as the FSM suggests.
Where did you get this diagram showing to apply RTV sealant on both sides of the gasket in the left corners? Page EM-36 of the A32 has a different diagram showing only to apply the RTV on the bottom side of the gasket?
Old Dec 25, 2011 | 05:42 PM
asand1's Avatar
Em18, timing cover assembly.
Old Dec 25, 2011 | 05:44 PM
asand1's Avatar
And EM34
Old Dec 25, 2011 | 05:53 PM
asand1's Avatar
'96 A32
Old Dec 25, 2011 | 06:36 PM
jholley's Avatar
Looks like the SEC 111-118-130-140-220 diagram changed for the 1998 FSM because it only shows to apply the RTV sealant on the bottom side of the gasket in those left corners. That's how I applied it on the rear valve cover 6,400 miles ago so I'm sure it'll hold.
tgreen
Oct 18, 2015 06:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
