Ap1 S2000 Rims
Old Jan 24, 2012 | 10:43 PM
nselca2's Avatar
Ap1 S2000 Rims
I was looking for a set of rims and came across a set of ap1 s2000 rims im kind of interested in. Before I jump the gun and get them, well these fit w/ no modifications? ie, no wheel spacers and wheel bore will fit perfectly?
Old Jan 24, 2012 | 11:27 PM
95Maxed's Avatar
They should fit. The bolt pattern is the same and from what I can tell, the offset should be fine.
Old Jan 24, 2012 | 11:36 PM
nselca2's Avatar
Alright, now Im deciding between the s2000 rims, some other tenzo rims I found on craigslist or a set of 2007+ spec v rims. Anyone run the new spec v rims on a 4th gen? Not sure how it'll look, but id imagine it would look decent. Opinons?
Old Jan 24, 2012 | 11:38 PM
95Maxed's Avatar
The spec-v rims may be small. Arent those 16's?
Old Jan 24, 2012 | 11:40 PM
nselca2's Avatar
Spec V Rims are 17's, ap1's are 16's.
Old Jan 24, 2012 | 11:41 PM
95Maxed's Avatar
huh. Scrap the ap1's you want at least 17's.
Old Jan 24, 2012 | 11:46 PM
nselca2's Avatar
Heres a link to what they look like if youre wondering:
http://www.google.com/imgres?q=2007+...:0&tx=86&ty=63
Sort of reminds me of the altima ser rims but a little less flashly. I like the way they look off the car, just dont know what theyll look like on a 4th gen.
Old Jan 25, 2012 | 12:03 AM
I wouldn't bother with them honestly. Sell sell sell.
Old Jan 25, 2012 | 12:41 AM
schmellyfart's Avatar
They might not fit. The ap1 wheels have a high offset.
Front:
16" x 6.5", +55 offset, 205 tire
Rear:
16" x 7.5", +65 offset, 225 tire
Stock 4th gen wheels are 15/16" x 6.5" +40 offset. The fronts should fit fine, but I doubt the rears will clear the struts.
The fronts will sit 15mm closer to the struts and the rears will sit 38mm closer to the strut than stock.
http://www.wheelspecs.com/Honda-S2000_wm935.aspx
http://forums.nicoclub.com/stock-nis...rt-t69378.html
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jan 25, 2012 | 06:19 AM
aackshun's Avatar
And onee moooaarrrr tinnnggggg.
To get Honda wheels to fit on Nissan cars you have to shave out the hubs on them, the bolt pattern may be the same but the wheel CAN NOT sit flush on our hubs because they are bigger.
If this were not true, i'd be rockin NSX rims right now.
Old Jan 25, 2012 | 06:36 AM
nselca2's Avatar
Thanks for the info guys. Ap1 rims are off the list. Guess im just going to keep looking around and find something else I like.
Old Jan 26, 2012 | 04:55 AM
max-r95's Avatar
Factory OEM Nissan wheels FTW, get a set of OEM Nissan wheels, a lot stronger and less ricey. Get some 370z wheels
Old Jan 27, 2012 | 10:21 AM
nselca2's Avatar
Alright, found a set of rims im interested in but dont want to get em until I know theyll fit. Rims are 17" roja lt5 rims. Offset is +40 all around.
Old Jan 27, 2012 | 10:37 AM
Wheel width?
Old Jan 29, 2012 | 06:45 AM
nselca2's Avatar
Every set of rims I find has a problem with them. Im just going to keep it simple and get new tires for my 350z rims. Quick question tho. I was planning on going 225/45/18 all around. Rims are 350z v1 touring rims. Will that be fine or will it make the rear look funny since the rear rims are wider.
Old Jan 29, 2012 | 08:36 AM
JDM BOIIA32's Avatar
I have the v2 on mine, my rears are 245/45/18 and it looks agressive from the rear
Old Jan 30, 2012 | 08:01 PM
nselca2's Avatar
Found the rims I want. Your help on whether they fit or not would be greatly appreciate. There rota g forces 18x9 et30. Tires are 225/40/18 if thats needed. Hub size is 73.1. Not sure if anyone has ran these rims on a max but if they have please post a pic, id like to see what they look like.
Old Jan 31, 2012 | 06:40 AM
nselca2's Avatar
Bizzump....need to know if theyll fit.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
