95 Maxima Multiple ECU Codes
Old Mar 5, 2012 | 08:35 PM
NIMAXIMA's Avatar
The check engine light has come on and I manually checked the codes. I have 0303, 0304, 0503, 0701, 0806. The information I have researched so far tells me the following are reported problems - Front left O2 sensor, Knock sensor, Front right O2 Sensor, Multiple cylinder misfire and Evaporative emission canister purge control solenoid valve. Is there something common that I should look at first? The car has close to 250k miles on it.
Old Mar 5, 2012 | 08:47 PM
Look at the "check items" and see if you see anything in common. Honestly, I'd start at the KS and front left O2 sensor then go from there.
BTW, the images are in code order as you listed.
Old Mar 5, 2012 | 09:29 PM
NIMAXIMA's Avatar
Thanks ChrisMan287. I will start there.
Old Mar 9, 2012 | 07:13 PM
Trini Boom's Avatar
From what I see, it seems that fuel is common in all cases...
Old Mar 10, 2012 | 08:54 AM
ADROX's Avatar
seems the misfires could cause the rest of the codes to me. maybe find out why it's missfiring. whether that be bad fuel or a ignition (spark) problem. wouldn't think a bad o2 would cause missfires in all cylinders and it's not like it's just one cylinder it's all 6. the fuel delivery problems may also be a problem, thats's definately a common cause. I would check my fuel pressure and spark before I bought anything.
mrc00l88
Jan 25, 2024 01:14 PM
lux97Max
19
Aug 27, 2015 07:48 PM
wingnut2006
Aug 15, 2015 04:16 PM
yat70458
Aug 3, 2015 01:16 PM
