help with knock sensor change on cali motor
Old Mar 13, 2012 | 09:30 AM
ADROX's Avatar
need to change my knock sensor but evidently car is from california. has the cali swirl crap in the way. how can I remove this or at least get it out of the way enough to replace my ks? need help today!
Old Mar 13, 2012 | 09:34 AM
I think you're definitely gonna have to pull that UIM off.
Old Mar 13, 2012 | 09:38 AM
dgoodhue's Avatar
I agree. I have CA emmisions 99 and I don't see how it would have been possible to do. While your taking off the uim, you can clean out the EGR tube.
Old Mar 13, 2012 | 09:40 AM
ADROX's Avatar
yeah I have to do that too. grrrrrrrrrrrrrrrr
Old Mar 13, 2012 | 09:42 AM
ADROX's Avatar
ok so what is the resistor trick that i have heard about? I need to get the ghost code for the knock sensor of to get the inspection sticker done. I can tackle the bigger job one weekend
Old Mar 13, 2012 | 09:43 AM
Do you run premium gas?
Old Mar 13, 2012 | 09:49 AM
ADROX's Avatar
it's my girlfriends car and she used to run plus in it cuz I made her but think I have her convinced to run premium now since there was a noticable gain in fuel mileage on the last couple tanks since she switched.
Old Mar 13, 2012 | 09:55 AM
ADROX's Avatar
it had a couple codes for months including the ks. it ran great for about a week after I got those cleared and then I got the dreaded 0111 evap code. the charcoal canister was junk so I dumped the loose stuff out, which was all of it, put it back on and reset the ecu. within a day the light came back on again for the evap system. have a new canister ordered but hasn't come in yet.
Throw a resistor in the KS harness and continue to run premium. Do not let her switch to anything lower.
Old Mar 13, 2012 | 09:58 AM
ADROX's Avatar
how do I install the resistor? is there a write up on it?
Old Mar 13, 2012 | 10:10 AM
You pretty much just put it in there and tape it up.
Old Mar 13, 2012 | 10:19 AM
ADROX's Avatar
where at in the harness? is the green plug the same as the ones without the cali motor? it has a few extra plugs in it in between the ks and the green connector.
Old Mar 13, 2012 | 10:21 AM
L_U_D_I_AMaxima's Avatar
I don't mean to jack this thread but how do you actually test the KS on the 4th gen? Using a multimeter? what numbers you should get?
Old Mar 13, 2012 | 10:22 AM
I'm not sure if it's the same on the Cali motors so I can't help there.
Old Mar 14, 2012 | 09:38 AM
ADROX's Avatar
I found where to plug it in. just follow the harness up and there is a connection before you will get to the main wiring harness that the green plug comes off of. damn californians.
Old Mar 14, 2012 | 09:44 AM
inbeforeyouknowwhosaystheksona99canbechangedin20mi nutes.....
Old Mar 14, 2012 | 09:49 AM
LOL I know who
kjlouis
Nov 24, 2018 06:09 AM
Slamrod
Sep 3, 2015 07:38 PM
maximusrising
Sep 2, 2015 09:55 AM
BobMax
Aug 21, 2015 07:38 AM
maxinout93
Aug 20, 2015 02:17 AM
