Stuck rotor/bolt size...
Old Apr 6, 2012 | 08:11 AM
tbaGd_jEw's Avatar
What size bolt fits those two holes that are used to help free stuck front rotors?
Old Apr 6, 2012 | 09:20 AM
MaxiNone's Avatar
the ones that hold the rotor to the knuckle, or the ones that hold the caliper bracket?
Old Apr 6, 2012 | 09:31 AM
tbaGd_jEw's Avatar
Not the caliper bolts. The two holes on the front of the rotor...I need a bolt that would fit in there. So pretty much the rotor to the knuckle...
Old Apr 6, 2012 | 09:59 AM
MaxiNone's Avatar
you got me there, mine didnt have those bolts when i got my car. usually theyre phillips screws. sorry i couldnt help but if you do some how take them off i wouldnt put them back on
Old Apr 6, 2012 | 10:04 AM
tbaGd_jEw's Avatar
They're just empty holes right now (as they should be), but I can't get the rotors off for the life of me. So I wanted to try using bolt(s) to push them out...
Old Apr 6, 2012 | 10:23 AM
benjie's Avatar
If the rotors are no good, try shocking it with a rubber malet. It should release the hold that the rust has on it.
Old Apr 6, 2012 | 10:26 AM
GGENIUS's Avatar
yeah tapping one side with a hammer, then tap the opposite side, should free it up. or maybe a few repeats.
Old Apr 6, 2012 | 10:41 AM
tbaGd_jEw's Avatar
Been there done that...
I mean I've slapped these things silly
Old Apr 6, 2012 | 10:50 AM
MaxiNone's Avatar
maybe kicking them, heat probably fused them together. the holes are probably big enough for 8mm or 6mm bolts
Old Apr 6, 2012 | 12:20 PM
tbaGd_jEw's Avatar
Definitely calls for something larger...
Old Apr 7, 2012 | 12:06 PM
dgoodhue's Avatar
I think they are m8 in the front. The rears are m6.
Old Apr 8, 2012 | 04:47 AM
njmaxseltd's Avatar
Use a BFH wack them from behind as you rotate the rotor. Might take a good 5 minutes but they will pop off.
Old Apr 8, 2012 | 10:49 AM
GGENIUS's Avatar
apparently hes already "been there done that." to which i wanted to respond, "then man the f up and hit it harder," but ill give him the benefit of the doubt. its just ive NEVER fully failed at getting a rotor off. just took more oomf.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
