Black 99 Se mANUAL not running.
ok, there is nothing i can do now i have to wait on my friend to charge the battery again before knowin' about the light. we tried spraying break cleaner in the intake while cranking it and the plugs made it rev. foot on the gas. Maybe ECU? cant find a problem. fuel has presure.
ANyideas why it cant spit
the engine turns over and will not start. we opened the airfilter and sprayed flamamble break cleaner and it ran for a moment. so it does trigger but wont start on it own
DO NOT COME BACK until the battery is charged and you can answer the questions!
Then answer the following questions, with YES or NO.
Is the security light ON when you try to start the car?
Do you have a Check engine light on?
If YES, what are the codes?
Do you have SPARK?
Do you have FUEL?
Have you done anything to the car before this immediate issue?
Do you have SPARK?
Do you have FUEL?
Well i have lost my only key. might be a WHILE untill theres a key. have to get a ne w one. but wounldnt you think it could be the ECU? the dealership nor firestone auto could find the problem. fuel delivery sound probable.
like thats the problem but they didnt find one and we checked the fuel pump back there.
How are you starting the car with no key then? Without a key and not being able to absolutely figure out if the security has been activated, we may not be able to help. From what I have been reading, a lot of people have been having problems with their 99's security lately so we need to make 100% sure this is not your case before moving to bigger things.
I had it and its cranks. Now the batterys out of power and the key is missing
I JUST LOST IT. yesterday! since i made a thread its gone till i get the car towed in a few months to get a new one made.
READ.
READ.
the key sends info to the computher i have a key to an auto from the junk yard the key was in it i took it was going to take everything i needed to get it to work but my car is a 5 speed so it wont work
NOt fireing but break cleaner will has the thing spewing. HElp??
I has a feeling this may be interesting to follow sooooo...subscribed
subscribed
