"S" pipe for o2 sensor after y pipe
Old May 17, 2012 | 11:56 AM
max1008's Avatar
Ok so I installed my whole exhaust a about a month ago and might have put this pipe on backwards. Does anyone have pics of this pipe installed. Need to know if the o2 is directionally facing the flow (essentially being hit head on by exhaust flow) or it directioned away from the flow.
If you didn't understand that I guess what I'm meaning is the tip of the o2 facing the front of the car or is the tip facing towards the rear.
I have had it both ways and was told from a friend that he has never seen it facing head on with the flow...so I swapped it.
Any help would be greatly appreciated!
Old May 17, 2012 | 12:10 PM
ShocknAwe's Avatar
Im not 100% positive but the direction doesn't matter that much. As long as its in the proper position then it will still read fine
Old May 17, 2012 | 03:16 PM
schmellyfart's Avatar
The pipe slopes downward as it goes to the rear of the vehicle.
Old May 17, 2012 | 05:00 PM
RA030726's Avatar
I'm nutty for Nissans
The original has a big end and little end. The larger opening is to the cat.
http://forums.maxima.org/4th-generat...d-new-one.html
Old May 18, 2012 | 05:19 AM
max1008's Avatar
thanks guys! 87 views and only 3 replies..lol. I knew I could count on someone in the org. that knew the answer...I tried a few searches but guess I could get it up with the words I was using to search with.
litch
123
Jan 4, 2024 07:01 PM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
